Pinch Bolt problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-11-2012, 05:41 PM   #1
nate4027
Fan#: 105354
What I Drive: 2003 Competition Orange Svt
FF Reputation: 1 nate4027 Good Standing Member
Pinch Bolt problems
I was changing out my right side drive axle, went to loosen the lower pinch bolt on the steering knuckle. My torx socket was slipping due to the head of the bolt being rusty. Anyway I can extract this bolt without having to drill it out and risk messing up the threads on the steering knuckle?
nate4027 is offline
Old 11-11-2012, 06:30 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Yours is threaded? Mine has a nut on the other side, but that's 05. 03 might be different. Use something like Kroil or PB Blaster on the back side of the pinch bolt, give it some time. I'd also use it on the front side to help clean the rust out of there. Best wishes.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-11-2012, 07:12 PM   #3
Tymes
Fan#: 94124
What I Drive: 02 SE SOHC SPI
FF Reputation: 8 Tymes Good Standing Member
And put some heat to it, you don't need to have oxyacetylene, I use a butane soldering torch (like in the picture), it can put enough heat on most bolts to loosen them up. And because it is small, you can direct the heat exactly where you want it.
Somewhere there's a DC10 struggling to get off the ground. I'm not a fan of wings on street cars, I like low key spoilers, but not something that you have to custom order from Boeing.
Tymes is offline
Old 11-11-2012, 07:16 PM   #4
fakitol
Fan#: 63209
What I Drive: 01 zx3 mtx,04 svt,01 zx3 atx, 02svt
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 fakitol Good Standing Member
Buy-Sell-Trade Rating: (11)
u don't use the torx socket use the other side with the nut! torx is just to keep it from slipping GL
fakitol is offline
Old 11-11-2012, 07:17 PM   #5
nate4027
Fan#: 105354
Thanks for the adivce fellas but its all boogered up. Looks like I will need to replace the lower ball joint which is no big deal but now need a new steering kunckle. How do you seperate it from the strut?
nate4027 is offline
Old 11-11-2012, 07:24 PM   #6
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,605, Level 43
Points: 4,605, Level: 43 Points: 4,605, Level: 43 Points: 4,605, Level: 43
Level Up 28% Completed
Forum Activity 3%
FF Reputation: 28 ah1f39 Great Standing Member
Had the threaded side break on an SVT.
Remove the nut. Hold the Torx head with Vise grips. If the threaded end breaks remove the control arm and knuckle and press the bolt out.
No need for knuckle or ball joint.
ah1f39 is online now
Old 11-11-2012, 07:27 PM   #7
nate4027
Fan#: 105354
The bolt can't be pressed out because it is threaded into the steering knuckle.
nate4027 is offline
Old 11-11-2012, 07:28 PM   #8
Tymes
Fan#: 94124
The strut just slips out once the pinch bolts are out, probably rusty so it might need some convincing.
Tymes is offline
Old 11-11-2012, 07:29 PM   #9
nate4027
Fan#: 105354
Thats what I thought. Just the crappy thing is I need a new steering knuckle now.
nate4027 is offline
Old 11-11-2012, 07:31 PM   #10
Tymes
Fan#: 94124
You might be able to use an extractor to get it out. Depending on how it broke of course.
Tymes is offline
