signs of clogged cat - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-10-2012, 03:28 PM   #1
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
What do I need to look for to find a clogged cat? I have an aftermarket one in my car and it looks like I bottomed out on it.
My car has no power and keeps blowing the vacuume lines for tie egr system. Exhaust noise is not as loud as it used to be at rear of car and the tone up front sounds different than a simple leak.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is online now
Old 11-10-2012, 04:04 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,314, Level 75
Points: 13,314, Level: 75 Points: 13,314, Level: 75 Points: 13,314, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
My experience with a clogged cat came one snowy day when the P/U didn't want to go over 40 mph. When I got to my destination (short trip) I noticed the exhaust didn't even blow the loose snow around! Revved it up & felt almost nothing coming out the pipe...
Start & idle OK, but no power.
Disconnected tail pipe B4 muffler, and it STILL was running quiet with NO tail pipe or muffler, Kinda a hint there!
Cleaned it out for an emergency fix - LOTS of noise without tail pipe then! And all worked normally when reattached & test driven.
Many folks have noted that with a partially plugged one it'll tend to get REAL hot (glowing) after a drive, so that would be another sign.
With the "Wack" you say it took, the ceramic could have broken & jammed up the pie with loose pieces.
Hopefully it's an easy one to disconnect, so you can possibly look inside &/or test with it disconnected...
luck!
P.S. - The one on the P/U was SO clogged it wouldn't even rev up fully with the throttle floored!
sailor is online now
Old 11-10-2012, 05:04 PM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
Huh too bad the idiot exhaust shop welded it in with no flanges. I may just gut the thing or remove it all together.
Old 11-10-2012, 07:53 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Hammer, steel rod, & a vacuum cleaner worked for that truck one, however I WAS able to get at one flanged end of it.....
Old 11-10-2012, 08:12 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Sounds like you have a clogged or damaged cat to me. When mine broke into pieces and clogged the pipe the exhaust note was much much quieter and I eventually had to damn near floor it just to keep up with traffic. That was when I decided to put my header on and sure enough when I took the cat off it was broken. You could even see where it was glowing red hot at one point, it discolored the metal so bad. Felt like I gain 40hp when I hollowed it out lol
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 11-10-2012, 08:13 PM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
Oh hey it's only us mods posting in this thread, kind of funny lol
Moderator for
Technical Chat
Old 11-10-2012, 08:29 PM   #7
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
It is more than likely a Cat problem.
Effin Cats LOL
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-11-2012, 08:58 PM   #8
scoutout
scoutout's Avatar
Fan#: 88324
What I Drive: 2002 black ford focus svt
FF Reputation: 1 scoutout Good Standing Member
would a bad cat let you have power for the first 5 mins the lose power? i have to floor it to jus keep up with traffic. but i can shut down the car for a while the start up and have power then it all happens again
2002 Black SVT # 2,844 148k miles and counting!
OIF VET 2007-2008
scoutout is offline
Old 11-11-2012, 09:32 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
It's POSSIBLE, but not as likely.
Loose pieces would have to fall out of the way when shut down, then plug it up again after running,,, NOT too likely...
Start a thread with all your info. and folks will try to help with YOUR issue...
Luck!
Old 11-11-2012, 10:04 PM   #10
scoutout
scoutout's Avatar
Fan#: 88324
been there done that lol. i have the code for cat want store oxygen and timing retard bank 1
OIF VET 2007-2008
scoutout is offline
