Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 11-10-2012, 08:53 PM   #11
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
No not really, I posted a pic of what it looked like before in a thread. I'm at work or I would post the pic for you to see. If I remember when I get home I'll post it for you to see.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 11-10-2012, 11:02 PM   #12
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
FF Reputation: 7 Blue5ive Good Standing Member
Buy-Sell-Trade Rating: (8)
Most titanium wrap I've seen done has lasted for a couple years b4 coming apart.
Team Focalize
Hatch Nation #9
"Some people feel the rain, others just get wet"
Blue5ive is offline
Old 11-11-2012, 08:51 AM   #13
SvviftSVT
LED ADDICT
SvviftSVT's Avatar
Fan#: 58277
FF Reputation: 8 SvviftSVT Good Standing Member
Buy-Sell-Trade Rating: (6)
i have dei titanium on mine.
no rotting issues for me...
and as far as rust.. the svt header is stainless steel, so rust shouldn't be a problem.
Track build will commence by Christmas (hopefully)
SvviftSVT is online now
Old 11-11-2012, 11:47 AM   #14
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
FF Reputation: 1 qweesy Good Standing Member
Buy-Sell-Trade Rating: (4)
heres a tip from someone whos wrapped many motorcycle exhausts,
You wont have to worry about rust the only time you need to worry about wrap is on "Titanium exhausts", more common on bikes over time the wrap will soak in moisture and can crack the Titanium.
Ive always used DEI brand wrap + spray
grind off the heat shield nubs,get a bucket and get the wrap wet, put the wrap on wet overlapping 1 inch of the 2in and pull it "TIGHT" as your wrapping to make it nice, I find the 1 inch alot easier to work with and looks nicer when done, but 2 inch may be the way to go on the SVT header since its bigger , also get the header wrap spray allow wrap to dry for 24hrs before you spray it on then allow another 24 hours for the spray to dry before you put it on the car.
I like black personally, if done this way it should last around 2-3 years.
qweesy is offline
Old 11-11-2012, 11:55 AM   #15
MattDzx3
MattDzx3's Avatar
Fan#: 99676
What I Drive: 2002 Red ZX3
FF Reputation: 2 MattDzx3 Good Standing Member
Does the titanium wrap need to sprayed with the silicone paint or is the just the fiberglass stuff?
SVT header, SVT cat-back, H&R Cup Kit
Rally Revolution #78, NW Posse #44
Originally Posted by brekkebooboo View Post
One does not simply "unstance" Their car
MattDzx3 is offline
Old 11-11-2012, 12:48 PM   #16
qweesy
qweesy's Avatar
Fan#: 12042
titanium is just the color just like white or black they are the same shit its made out of fibers and lava rock
qweesy is offline
Old 11-12-2012, 07:40 AM   #17
Quickone4u
Fan#: 104673
What I Drive: 2004 Pitch Black SVT
FF Reputation: 1 Quickone4u Good Standing Member
I don't believe this to be the case. On DEI's site they say the Titanium wrap is different then the other regular wraps they have. They specifically say that the spray is not needed/recommended with the titanium wrap and that it also does not need to be soaked in water before application due to it's much more pliable nature. Just what I've seen and read about it anyway.
04 SVT-Fswerks Race Exhaust,Taylor Thundervolt 8.2mm Wires,Mastercraft Copper plugs
Quickone4u is offline
Old 11-12-2012, 07:46 AM   #18
SvviftSVT
LED ADDICT
SvviftSVT's Avatar
Fan#: 58277
yes. this.
the dei titanium wrap is indeed a different make up.
Old 11-12-2012, 08:30 AM   #19
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
Not this!
Originally Posted by SvviftSVT View Post
yes. this.
This!
Team Focalize
Hatch Nation #9
Blue5ive is offline
Old 11-12-2012, 11:01 AM   #20
qweesy
qweesy's Avatar
Fan#: 12042
Ok the only diffrence between the Black,White, Tan and the Titanium is
1) its a different kind of weave. (both look good in my opinion)
2.) in the FAQ's it says If you are going to wrap any kind of steel pipe we recommend using DEI HT Silicone Coating to spray the header or pipes prior to applying Titanium exhaust wrap. However, there is no need to apply DEI HT Silicone Coating to Titanium wrap. ( so you still need the coating you just put it on before instead of after)
3.)Withstands 1800˚F direct/2500˚F intermittent heat rather than Withstands 1200°F direct/2000°F of the standard wrap.(average exhaust temps on headers of a well tuned vehicle shouldnt go above 1000 degrees.... and some seen as high 1600 degrees EGT on some turbo applications with lean conditions)
4.) it says you dont "have" to wet it thats cool dont but I guarantee you it will look better if you wet it first Ive done it both ways wet has always looked better plus it sticks to the pipe better as you're wrapping it.
5.) Obviously the colors and really its just a marketing gimmick haha they are practically the same price, hah and some of you are saying the Ti only lasted a few months???? Ill stick with black EVERY time Ive done it its been good for 2-3 YEARS
Black = 2" wide x 50' roll, $57.40
Titanium = 2" wide x 50' roll, $62.19
Tan/White = 2" wide x 50' roll, $53.22
qweesy is offline
