Old 11-09-2012, 08:29 PM   #1
Mphillips717
Fan#: 105842
What I Drive: 2005 red ZX4
FF Reputation: 1 Mphillips717 Good Standing Member
I seriously need help!!!!
I have an 05 zx4 with 135000 miles it started dying, replaced the alternator seemed to run fine for about a month then started dying again so I replaced the battery, ran well for a month again and now I have replaced the starter and while doing that the battery completely died so I charged it which took about ten minutes of driving the car completely died out what could possibly be wrong????
Mphillips717 is offline
Fan#: 1
Old 11-09-2012, 08:50 PM   #2
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
FF Reputation: 9 UnbridledCarnage Good Standing Member
moved ya over to tech chat for more help! Welcome to FF!!!
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
Mod for General Chat, Ford General chat, FocusXtreme, KY,NC,SC sections
Originally Posted by matmatician View Post
Racecar > Comfortable female.
UnbridledCarnage is offline
Old 11-09-2012, 09:03 PM   #3
Mphillips717
Fan#: 105842
Where do I find the tech forum?
Old 11-09-2012, 09:04 PM   #4
Mphillips717
Fan#: 105842
Never mind I see you just moved it here haha
Old 11-09-2012, 09:04 PM   #5
sam fisher
APOCALYPSE DUDES
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
FF Reputation: 3 sam fisher Good Standing Member
your thread is now in it , he moved you
sam fisher is offline
Old 11-09-2012, 11:03 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
I'm not following your though process of throwing parts at the car ...
"started dying" - how? Did the lights dim then the car shut off? were lights flickering?
The battery is generally most often found to be 'bad' when the car will not crank.
The starter has very little impact on anything I see you problem could be.
But,
I need more info on this "dying" thing first.
iminhell is offline
Old 11-09-2012, 11:32 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
You replaced everything except the wires. That would be my next thought, also the alternator pigtail likes to get pulled out causing problems. Other than that you need you clarify what is exactly happening like iminhell said.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 11-10-2012, 01:48 AM   #8
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
Charge the battery FULLY on a charger, auto stores now do it for free. Driving a car for 10 minutes does not do that, battery being low on charge will simply fool you into buying more unnecessary stuff. Get alternator checked for output too.
More details again like they say, your story is wide open at this point, meaning 50 things could be wrong there.
amc49 is offline
Old 11-10-2012, 08:03 AM   #9
Mphillips717
Fan#: 105842
Ok I'm sorry I was unclear, I would be driving and out of nowhere the car would stall out so I took it to auto zone and they checked the battery said it was fine but noted the alt. needed checked so I removed the alternator and took it up there to get tested, afterwards they found it was bad so I replaced it, it ran for about a month seeming fine and one day it would not start so I took the battery to autozone and it was bad so I replaced it on August 16 2012 it ran fine up until the other night. when I attempted to start it the starter was just clicking so I removed it and took it to autozone and they tested it which failed so I replaced it. While replacing the starter, the battery died completely. I removed the battery and took it to auto zone where they charged it fully, I brought it home, installed it and after only ten minutes of driving it lost all lights and then it stalled out, got jumped and it did the same again. Sorry for being unclear using mobile device previously.
Old 11-10-2012, 09:39 AM   #10
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
What I Drive: 2001 Red ZX3
FF Reputation: 82 BC_ZX3 Excellent Standing Member
Some more suggestions for you:
1. Get a multimteter so you can measure the output of the alternator and state of charge of the battery yourself. As a preliminary check, the battery voltage should be above 12V with the car off, and 14.5V+ when running. Also the charging system wiring and connectors that join various charging system components should be inspected thoroughly for chafes/shorts and breaks; the Focus is known for a dodgy alternator connector plug as mentioned by sleepyboy. Remove and clean the battery terminals thoroughly and check for tightness.
2. Don't assume a part is good simply because it was already replaced. Test it again. I'm referring to your Autozone alternator which seems to have a very spotty reputation for quality on this site. The usual advice is to have an automotive electrician rebuild your original one.
I suspect your alternator has failed again or there is a wiring problem - regardless of the cause, your charging system is not functional - and you're simply draining/destroying batteries. The clicking sound is the starter relay not getting sufficient juice and stalling while driving indicates to me the car is/was running on battery power alone. There was likely nothing ever wrong with the starter motor as stated by iminhell.
BC_ZX3 is offline
