Wire/Part identification - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-09-2012, 08:32 AM   #1
RugbyMadNut
Fan#: 104477
What I Drive: 2002 Silver Saloon
FF Reputation: 1 RugbyMadNut Good Standing Member
Hi All,
I'm going to replace my spark plugs, HT leads and ignition coil at the weekend. This is because I've been getting juddering and misfires at low revs in the lower gears.
I was checking last night that I had the right Torx screwdriver for the ignition coil when I noticed a wire coming from the cylinder head between plugs 2 and 3.
Any idea what this is or what it is connected to? A sensor perhaps?
It's a bit dirty, wet and grotty in the channel the plugs sit in on the cylinder head... this can't be good right? I'll give it a good clean before I remove the plugs first!
Any answer on the unknown wire would be great!
car details = 2002, 1.6 Ghia saloon.
RugbyMadNut is offline
Old 11-09-2012, 09:04 AM   #2
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,881, Level 59
Points: 7,881, Level: 59 Points: 7,881, Level: 59 Points: 7,881, Level: 59
Level Up 66% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Hello and welcome to FF,
Is it possible for you to get a picture of your motor and the wire your talking about? Sounds like it might be some type of sensor wire that has came unplugged causing your problems.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 11-09-2012, 09:42 AM   #3
RugbyMadNut
Fan#: 104477
I'm at work at the moment so I've used a stock image of the 1.6 engine.
The wire in question is marked with the red arrow, between plugs 2 and 3.
Old 11-09-2012, 10:45 AM   #4
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 17 nilskje Great Standing Member
Head temp sensor ie. engine temp sensor
nilskje is offline
Old 11-09-2012, 05:01 PM   #5
RugbyMadNut
Fan#: 104477
Probably not good that it's sitting in a pool of water then!
Old 11-09-2012, 09:20 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,422, Level 75
Points: 13,422, Level: 75 Points: 13,422, Level: 75 Points: 13,422, Level: 75
Level Up 44% Completed
Forum Activity 99%
Probably not!
By the way, over here we have a replacement "pigtail" connector to the coil avail. from Ford, since bad wires/loose connections there can cause issues like you describe.
It's a part to look closely at when you're in there doing the work you planned....
Luck!
sailor is offline
