I done goofed - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 11-08-2012, 10:10 PM   #1
Neptune15
Neptune15's Avatar
Fan#: 91691
What I Drive: '07 ZX3
FF Reputation: 1 Neptune15 Good Standing Member
I done goofed
So I installed my SS lines. Besides the retaining clips being a PITA, everything went smoothly.
Then I checked the brake fluid reservoir and found it to be nearly empty. The brake pedal feel was nearly non existent, and the pressure would not build up, even after bleeding the brakes (2 man method). The pedal sinks to the floor.
My guess is that I ran the m/c dry, and my bleeding method isn't getting the air out.
Any help is appreciated, especially if I can avoid a mechanic.
Neptune15 is offline
Old 11-08-2012, 11:58 PM   #2
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Did you bench bleed the master cylinder?
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 11-09-2012, 06:49 AM   #3
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
FF Reputation: 1 bbcobra Good Standing Member
just start over. bleed the master cylinder then work your way around bleeding at each corner.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is online now
Old 11-09-2012, 07:18 AM   #4
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
do you have ABS?
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is offline
Old 11-09-2012, 08:11 AM   #5
Neptune15
Neptune15's Avatar
Fan#: 91691
I do not have ABS. I did not bleed the m/c.
I'm going to have to learn how to do this. If anyone has a well-written guide that would be helpful.
Old 11-09-2012, 08:22 AM   #6
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
did u bleed in this order: pass rear, driver rear, pass front, driver front?
BigRed03 is offline
Old 11-09-2012, 03:01 PM   #7
Neptune15
Neptune15's Avatar
Fan#: 91691
Yes.
Old 11-10-2012, 01:13 AM   #8
08focusse
Fan#: 94107
What I Drive: 2008 Ice Blue Focus SE
FF Reputation: 3 08focusse Good Standing Member
You need to start with bench bleeding the master before you mount, to do this, you install the hoses that come with it into each fitting and route them in to the reservoir and with a full reservoir , pump the master with a large screw driver till there are no more air bubbles .Then you can install it. Once you have it installed, start at the right rear wheel and go around and bleed each wheel .
I have a pdf file that states how to do this from ford not to sure how to u/l it here
08focusse is offline
Old 11-11-2012, 03:35 AM   #9
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
Just as an FYI, it was getting to the point in the auto store that most M/C makers were not including the bleeding hoses any more as a cost saving measure. Only the most expensive had them and even then not all did. Pretty funny as one of the requirements for lifetime warranty was that you had to bleed the M/C before installing it.
amc49 is offline
Old 11-11-2012, 11:37 AM   #10
Neptune15
Neptune15's Avatar
Fan#: 91691
My current m/c isn't faulty, I'm not sure why it's being suggested that I'm installing a new one. There's just air in there.
