HELP! Strange electrical issue, car won't start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-08-2012, 08:37 PM   #1
hurtinfocus
hurtinfocus's Avatar
Fan#: 835
What I Drive: 03 SVT (RS conversion)
Points 10,179, Level 67
Points: 10,179, Level: 67 Points: 10,179, Level: 67 Points: 10,179, Level: 67
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 4 hurtinfocus Good Standing Member
Buy-Sell-Trade Rating: (23)
back story: I've been neck deep in an RS conversion....so my car has been "sitting" in the garage for about 2 months while I did all of the bodywork and paint on it. last week I went to pull the car out of the garage and when I turned the key I had NOTHING....so I checked voltage on the battery and it was super low....so I pulled the battery and put it on a charger....it wouldn't take a charge so I figured the battery was dead.
I went and bought a brand new battery off the shelf at the local parts store and tossed it in the car. BAM started up and backed it out of the garage. left it there for a couple days until I had time to put the fenders and front bumper back on so I could drive it.... moved it back in the garage to re-assemble just fine....then when I was done I got back in thinking I was finally going to take the maiden voyage, only the car wouldn't start!
Checked voltage, and I've got 12.4ish volts at the battery. it's doing some WEIRD stuff....I shot a video, hopefully someone can shed some light on what's going on here....
I did check the loom that goes from the roof into the hatch door, and no wires have broken through the insulation so that's not it.....
VID:
http://smg.beta.photobucket.com/user...94229.mp4.html
My majorly huge hand-made Focus RS replica build: http://www.focusfanatics.com/forum/showthread.php?t=289061
hurtinfocus is offline
Old 11-08-2012, 08:42 PM   #2
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
There's a problem with your video link. Nevermind, it didn't load right the first time for some reason.
I think you should make damn sure that new battery is fully charged. It was sitting on a shelf for a long time at a store, and it didn't really charge in the time you had the car running. I know it has 12.4 volts, and that should easily start a car if all the batteries cells are there (and they should be with a new batter), but you never know.
6SPD_soul is offline
Old 11-08-2012, 10:21 PM   #3
fakitol
Fan#: 63209
What I Drive: 01 zx3 mtx,04 svt,01 zx3 atx, 02svt
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 fakitol Good Standing Member
Buy-Sell-Trade Rating: (11)
bad terminal connection clean them up just in case
fakitol is offline
Old 11-08-2012, 11:17 PM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Please define ""only the car wouldn't start!""
Does that mean that the engine does turn over like normal except it does not start or does it mean it does not even turn over or turns over slowly
mikeeshaq is offline
Old 11-09-2012, 06:06 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Couldn't watch video. User doesn't have access- blah blah blah.
What weird stuff is it doing exactly? Problems with the small ground wires on the neg terminal caused my cars's wipers to come on without the switch being on, and the radio was blasting, but the volume didn't work or something. I can't remember all the funny stuff it did.
Also, as Mikeeshaq asked: Is this a no crank issue, or crank but not start?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-09-2012, 09:24 AM   #6
hurtinfocus
Fan#: 835
Forum Activity 3%
it is a no-crank issue. Here's what's going on in the video....
get in car
insert key, turn to on position
hear fuel pump prime, and the chime
depress clutch, chime goes away, dash dims
attempt to start, dash goes black, then flickers while a distinct ticking sound appears
while key still in "on" position, if brake pedal is depressed dash goes black and radio resets
those little ground wires off the negative teminal all seem to be good (and were not tampered with aat any point)
I'll try cleaning the terminals and possibly removing the small grounding wires and cleaning the contact surfaces.....
For what it's worth.....the day this all happened it was about 40 degrees when I first moved the car to put the front clip back together, and about 30 degrees with frost developing later that night when I had it finally together and tried to hop in for a drive...
(battery is BRAND NEW)
Old 11-09-2012, 02:39 PM   #7
hurtinfocus
Fan#: 835
Forum Activity 3%
ended up being dirty/corroded cable ends and dirty/corroded ground wire connections on the framerail. GOT IT!
