'04 FF base model - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-08-2012, 05:28 PM   #1
badhog
Fan#: 105811
What I Drive: 2004, dark blue focus, base model
FF Reputation: 1 badhog Good Standing Member
'04 FF base model
Greetings.... I am having an issue with my ignition switch....it won't turn. I know how to remove the tumbler assembly, but cannot turn the key to get it to that point. Any pointers on how to remove the ignition tumbler assembly without destroying the metal housing around it?
badhog is offline
Old 11-08-2012, 05:37 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,709, Level 76
Points: 13,709, Level: 76 Points: 13,709, Level: 76 Points: 13,709, Level: 76
Level Up 15% Completed
Forum Activity 11%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Can you remove the key? Hopefully you can or else your screwed.
If not then insert your key, Tap the back side of the key. This helps the tumblers move into place and with a little paitience it should turn. once you get it to trun remove that sucker and get a new one. A locksmith can provide and key a new one for you for $100 or less.
SkyPilot is offline
Old 11-08-2012, 06:05 PM   #3
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
^^^perfectly said. I had to do that on my 04.
GreySkorpion is offline
Old 11-09-2012, 07:00 AM   #4
badhog
Fan#: 105811
04 FF base
Thanks Skypilot....will give that a try when I get home from work...post update later...
badhog is offline
Old 11-09-2012, 06:08 PM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,996, Level 74
Points: 12,996, Level: 74 Points: 12,996, Level: 74 Points: 12,996, Level: 74
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is online now
Old 11-09-2012, 06:57 PM   #6
badhog
Fan#: 105811
Thanks Skypilot...it worked like a charm!
badhog is offline
