Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 11-08-2012, 12:36 PM   #1
BOOSTA
BOOSTA's Avatar
Fan#: 36047
What I Drive: 2003 White ZX3 2.3L Turboed Duratec
FF Reputation: 8 BOOSTA Good Standing Member
Buy-Sell-Trade Rating: (11)
Rear Brake Kit upgrade kits
Hey was looking to upgrade my rear drums to disc brakes, cant really find anything online anywheres, anyone know where I can get the upgrade kit?
I have an 03 ZX3 Duratec
----The Honda Eater----
BOOSTA is offline
Fan#: 1
Old 11-09-2012, 06:38 AM   #2
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
How far do you want to go? What size do you want to end up w/? I was looking for the svt caliper brackets like everone else & ended up going w/ tce's wilwood 11.75 kit. I'm surprised no one to machining of the svt caliper brackets.
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 11-09-2012, 08:54 AM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
Unfortunately Ford Parts quit supplying the SVT rear brake kit and the so called rally kit (slightly smaller than the SVT rotors). These were the two most common replacement kits. The other common option was to find those from Foci's equipped with advance trac (Anti-lock system) in a junk yard. You can get most of the needed parts "piece meal" but the resulting overall cost would be very high doing it that way.
There are several big brake kits available from major performance suppliers but these tend to be quite pricey and require improving the front brakes to maintain the proper brake bias. A bigger brake on the rear alone can cause it to prematurely lock-up before the front (less weight back there) which is bad for handling and control.
Geezer is offline
Old 11-09-2012, 03:53 PM   #4
BOOSTA
BOOSTA's Avatar
Fan#: 36047
Thanks guys Felix Im going to message ya on where i can fine some tce wilwood kit
BOOSTA is offline
Old 11-09-2012, 05:43 PM   #5
Richard Bridgette
Fan#: 99824
What I Drive: SCCA GT-1 road race Mustang
FF Reputation: 2 Richard Bridgette Good Standing Member
rear disc brakes
Just got back from the junk yard with front steering knuckles, hubs, rotors, and calipers from a 2005 Focus that will fit any 2001 to 2004 with just a change in the ball joint to the 2005 ball joint. The 2005 rotor is approximately 11 inches diameter, compared to the ten inch front rotors that came on 2000 through 2004. The rear disc brakes from any Focus up through 2007 will bolt right on to replace rear drums. Find a rear disc Focus in the junk yard and buy the splash shield, stub axle, hub, rotor, and caliper. The rear rotors are ten inch solid rotors. All that is needed are the disc brake ebrake cables. I paid $75 for each corner, total $300. Richard Bridgette, Huntersville, NC.
Richard Bridgette is offline
Old 11-09-2012, 05:55 PM   #6
ah1f39
Freezing in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2002 Liquid Grey ZX5, 2000 Explorer
FF Reputation: 28 ah1f39 Great Standing Member
The Advancetrac rear disc parts are still available from Ford.
ah1f39 is offline
Old 11-10-2012, 06:42 AM   #7
felixthecat
Fan#: 80663
Which are what the ST's use. ^^^^^Now it be great to see FRPP's to make that into a kit for you guy's. You would think that Ford would replace the svt kit w/ the ST rear kit, since Ford doesn't want to produce the svt caliper bracket for some reason. Why, IDK.
