Weird sound from engine - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-08-2012, 06:02 AM   #1
YoYasu
Fan#: 92608
What I Drive: 2003 2.3L zx3
Points 346, Level 6
Points: 346, Level: 6 Points: 346, Level: 6 Points: 346, Level: 6
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 YoYasu Good Standing Member
This noise has been happening for as long as i've owned the car(about 3 years now). It only happens sometimes though. I find that the noise gets louder as rpm increases rather than speed. Over the 3 years i've owned it, the noise hasn't got any worse. Anyone know what it might be?
http://www.youtube.com/watch?v=Ts8bvNpSNKE
It's a 2003 zx3 2.3L
YoYasu is offline
Old 11-08-2012, 07:21 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,819, Level 76
Points: 13,819, Level: 76 Points: 13,819, Level: 76 Points: 13,819, Level: 76
Level Up 43% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I'd say it's your timing chain, tensioner & chain guides. Check your tensioner & chain guide's. While your there, I'd be pulling out your balance shafts also= add a bsd plug too. It'll hold another 1 qtr of oil, which is a good thing. How many miles?
felixthecat is offline
Old 11-08-2012, 10:20 AM   #3
YoYasu
Fan#: 92608
Points 346, Level 6
just under 100k
am i losing hp from this?
YoYasu is offline
Old 11-09-2012, 07:17 AM   #4
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Originally Posted by YoYasu View Post
just under 100k
You could as there would be slack in the chain, & that would affect the cam timing.
Old 11-12-2012, 12:33 AM   #5
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Slack in a chain or belt won't affect cam timing as timing is dependent on the number of teeth in either the chain or belt, not the relative length or tautness. The relation between the cam and crank remains 2 revolutions of the crank to every 1 of the cams. However in extreme cases of say a tensioner completely failing it will cause the motor to run like crap purely because the crank accelerates and then there is a delay on when the cams turn because that slack must be taken up. Often the motor won't run at all.
If there is a bad tensioner in your car, it probably isn't affecting how the car runs, at least at this time. Hydraulic tensioners can tend to make knocking sounds if they are failing.
jetrinka is offline
Old 11-14-2012, 11:02 AM   #6
YoYasu
Fan#: 92608
Points 346, Level 6
Is it normal for this to last so long? Like i've said, i've had the car for 3 years now with the noise coming on and off. It hasn't got any worse.
YoYasu is offline
