Heat not working. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2012, 12:22 PM   #11
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
thank you for your help
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-16-2012, 12:39 PM   #12
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
What I Drive: A magical pony by the name of Sally
Points 11,236, Level 69
Points: 11,236, Level: 69 Points: 11,236, Level: 69 Points: 11,236, Level: 69
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 4%
FF Reputation: 9 LouBomb Good Standing Member
did you check your coolant?
2000 Turbo Zx3
2003 Pitch Black SVT
2000 SPI 220k miles all original THE UNICORN
Focus Revolution Club
Formely IMPORTKILLA35
LouBomb is offline
Old 11-17-2012, 01:48 PM   #13
Fattie
Fan#: 46016
lol , yea. the blower motor doesnt have power. nothing to do with the heater core.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-17-2012, 05:07 PM   #14
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,394, Level 75
Points: 13,394, Level: 75 Points: 13,394, Level: 75 Points: 13,394, Level: 75
Level Up 36% Completed
Forum Activity 99%
Fuse, Switch, resistor, motor.
In order of ease to check, you already checked for power at the motor - so next check the fuse for power on both sides (installed) - then look for power at the resistor pack & lastly the switch (just 'cause it's hardest to access).
FWIW, a good procedure with the meter is to test a known good 12v. source, to make sure you've got a good ground & the meter is working/set right.
Just hooking to metal doesn't always work due to ungrounded parts or poor connections. (getting fooled is easy, getting dependable results takes some effort)
Luck!
sailor is online now
Old 11-18-2012, 11:26 AM   #15
Fattie
Fan#: 46016
Luck!
thanks , i tested my other focus' heat at the blower motor and when the switch was off both wires read about 11.5 then with the switch on 4 one wire read 11.5 the other read 0.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-18-2012, 02:34 PM   #16
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Shucks Dang!
Your results just reminded me of hearing that it's a "switched ground" system...
So, remembering the no power at the motor result you got, the culprit is likely in the power supply side.
Blade type fuses have test ports on the top, you can probe for power on both sides without removing them to both check the fuse & see if the circuit has power...
Luck!
Old 11-25-2012, 02:41 PM   #17
Fattie
Fan#: 46016
so i feel like a complete moron. after replacing all the parts all it was was a fuse.
now i had checked all the regular size fuses , but i never checked the really big ones under the hood. sure enough , the 40 amp was blown , 3.50 $ later i had working heat.
i really feel dumb. but now i have heat again , and an extra blower motor , switch and thermal fuses.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-25-2012, 02:49 PM   #18
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 markwb Good Standing Member
Well, good to hear you have resolved the problem. Don't be too hard on yourself now, we all can make mistakes at times. Congratz on the fix! :) stay warm.....
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 11-25-2012, 03:19 PM   #19
Fattie
Fan#: 46016
thanks , its nice having heat again.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
