Heat not working. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-07-2012, 03:21 PM   #1
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
Heat not working.
So ive had problems with my heater for about 2 years now.
the first issue was the where the plug connects into the blow motor , well , it melted. so i cut the plug off and the spliced on a new connector and got a new blower motor. problem fixed.
now , my heat doesnt work again , well it hasnt worked since this past winter , and its starting to get cold again.
so , i replaced the wiring connector , the blower motor , the switch , and the resistor. still no heat , any ideas guys ? i check all fuses under dash , does the heater have a relay ? thanks for the help.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-07-2012, 03:22 PM   #2
Mitch1989
Mitch1989's Avatar
Fan#: 105151
What I Drive: 2001 Zx3
FF Reputation: 3 Mitch1989 Good Standing Member
Does the blower motor come on and it's just not hot?
Mitch1989 is offline
Old 11-07-2012, 05:09 PM   #3
Fattie
Fan#: 46016
blower motor does not come on at all.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-07-2012, 05:15 PM   #4
Mitch1989
Mitch1989's Avatar
Fan#: 105151
Does it come on w/ AC on?
I would check the wiring coming off the back of the knob w/ a volt meter and see if you're getting anything from that. If you're not, I'd lean towards the switch, if you are getting voltage off of it, I'm not sure what there is left other than, as you mentioned, a relay or fuse...
Old 11-07-2012, 05:41 PM   #5
Fattie
Fan#: 46016
no ac , i replaced the switch. the heat in my other in my other focus works , so im gunna pull the parts from those and go from there.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-08-2012, 04:46 PM   #6
Fattie
Fan#: 46016
anyone know of anything else i can check ? i dont have a multi meter but ill try to find one tommorro.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-08-2012, 05:43 PM   #7
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 markwb Good Standing Member
Get the multimeter. Remove the connector from the blower, set the meter to measure dc voltage, turn blower switch to position 4, place black meter lead on chassis of car, use red meter lead to probe connector for power (+12vdc) Report back with results please. Thank you.
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 11-08-2012, 07:39 PM   #8
Mitch1989
Mitch1989's Avatar
Fan#: 105151
Harbor freight usually has them for less than $10.
Old 11-15-2012, 06:15 PM   #9
Fattie
Fan#: 46016
results , one wire read .25 , the other would go to .10 then right down to 0.
so there is a little power im guessing , but i think i have a short somewhere.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 11-15-2012, 08:29 PM   #10
markwb
markwb's Avatar
Fan#: 105077
Points 298, Level 5
There is no power at the connector (+12vdc) This is certainly not good. A ventilation control schematic will be necessary. We do not know how or if power to operate the blower is coming direct from speed changer switch or relay controlled or what not.
Mark
IBEW Local 261
markwb is offline
