EGR woes... Help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-07-2012, 02:59 PM   #1
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
Unhappy EGR woes... Help!
I have a Zetec with an FSwerks 4-to-1 race header on it. When I installed it, I accidentally kinked my EGR tube. I got a new EGR tube, and installed it, and reset my ECU... Now the stupid P0401 (EGR Insufficient Flow) code came back on... What do I do now?
Andrews-bad-SE is offline
Old 11-07-2012, 03:27 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,596, Level 53
Points: 6,596, Level: 53 Points: 6,596, Level: 53 Points: 6,596, Level: 53
Level Up 23% Completed
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
Buy-Sell-Trade Rating: (23)
Disconnect the battery cables for a few minutes and see if that works. Or, have the code reset.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 11-07-2012, 06:34 PM   #3
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 markwb Good Standing Member
It also may reset automaticly after so many start cycles.
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 11-07-2012, 07:23 PM   #4
drunkyoda
Hmmmmm
drunkyoda's Avatar
Fan#: 65151
What I Drive: 2003 Pitch Black LX
Points 13,451, Level 75
Points: 13,451, Level: 75 Points: 13,451, Level: 75 Points: 13,451, Level: 75
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 9 drunkyoda Good Standing Member
ya you may just have to drive it for a while.
2003 Focus Sedan - Sold but not forgotten
2014 Mustang V6 - Current
drunkyoda is offline
Old 11-08-2012, 12:11 PM   #5
Andrews-bad-SE
Fan#: 100389
I have a MAC Tools code reader tool, I've reset it a few times. Do I just have to clean the valve... AGAIN??!!?!?!? :(
Old 11-09-2012, 11:57 PM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Check the causes listed below. DPFE sensors fail often. The code may be coincidental to EGR tube replacement.
P0401 - EGR Flow Insufficient Detected
The EGR system is monitored during steady state driving conditions while the EGR is commanded on. The test fails when the signal from the DPF EGR sensor indicates that EGR flow is less than the desired minimum.
Causes:
Vacuum supply
EGR valve stuck closed
EGR valve leaks vacuum
EGR flow path restricted
EGRVR circuit shorted to PWR
VREF open to D.P.F. EGR sensor
D.P.F. EGR sensor downstream hose off or plugged
EGRVR circuit open to PCM
VPWR open to EGRVR solenoid
D.P.F. EGR sensor hoses both off
D.P.F. EGR sensor hoses reversed
Damaged EGR orifice tube
Damaged EGRVR solenoid
Damaged PCM
Perform KOER self-test and look for DTC P1408 as an indication of a hard fault. If P1408 is not present, look for contamination, restrictions, leaks, and intermittents.
BC_ZX3 is offline
