| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#1 | ||||
How To: Reset TPMS with no learning tool
Hey guys and girls. I came across a way to train new TPMS sensors. Use this if you're installing winter wheels/tires that have sensors already installed, or even if you are just doing a tire rotation. Not sure if this has been posted before. I tried searching but didn't see it posted anywhere. No need to go and buy the TPMS learning tool.
1) Make sure your tires are inflated to the recommended psi. Mine is 40psi. 2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal. 3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo. 4) Release air pressure in the front left tire until you hear the horn honk. The LCD display should now read "Train right front tire". 5) Release air pressure in the right front tire until you hear the horn honk. 6) Repeat for the the right rear tire, and then the left rear tire. 7) You should now see "Training Complete" in the LCD display. 8) Fill your tires back up to the recommended pressure. Enjoy! |
Remove Advertisements |
Fan#: 1
#2 | ||||
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at 3.5.1 52k miles and counting... |
#3 | ||||
I have to swap my ''all season'' tires for my winter tires this week-end. I will give this a try. Altho I have TPMS on my steelies wich were dealer installed when I got the car in nov 2011, I guess it wont cause no harm to have the old TPMS ''relearning''...just in case.
Where did you found this information btw ??
2012 Oxford White SEL Sedan 303A + winter package + Moonroof + 16'' OEM |
#4 | ||||
No need to drive on them. Just put the wheels/tires on the car. Saw this on YouTube with a guy doing it to an F150 so I thought I would give it a try with my car and it worked like a charm. The TPMS learning tool that I bought from TireRack with my snow tire package didn't work at all, so I started searching the web for answers, and came across this.
http://www.youtube.com/watch?v=kMkSfgyCCDI Fast forward to about 4:20 for the TPMS part. |
#5 | ||||
#6 | ||||
Well I'm up to 2000 miles since installing my winter wheels with tpms sensers pre installed. Haven't yet had a warning light after installing and they've never been programmed
#7 | ||||
Sent from my iPad
2012 Mustang Brembo GT - Kona Blue 2013 Acura RDX - Alabaster Silver |
#8 | ||||
It doesn't matter where he stores them, the sensors go to "sleep" within a few minutes of non-motion. Ford has been using "auto-training" tpms sensors for a few years now. This has been discussed at nauseum in the other threads, if you just want the warning light to go out, no programming is needed. You can train them by position to the BCM if you like, but, since our cars do not display separate pressures, doesn't make much of a difference.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue 2012 Escape Limited w/park assist 2010 F150 Supercrew XTR 5.4 4x4 2008 Kawasaki Concours 14 (street) 2008 Kawasaki ZX10R (track only) |
#9 | ||||
why why didn't you post this earlier, I've purchased the TPMS tool for $35 bucks damn it |
#10 | ||||
My Brother doesn't even bother with TPMS on his winter wheel package. Drives all winter without having the warning light come on. Guess what? That's right, his summer wheels are in the garage. By the way the term is "ad nauseum"
| Thread Tools | |
| Display Modes | |
