Rear wiper not working & Rear Hatch button not working - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-05-2012, 05:58 PM   #1
herenow
Fan#: 105707
What I Drive: 2001 red zx3
Points 333, Level 6
Points: 333, Level: 6 Points: 333, Level: 6 Points: 333, Level: 6
Level Up 66% Completed
FF Reputation: 1 herenow Good Standing Member
Hello,
I apologize if I’m not posting in the correct location, in advance.
I tried searching google, and this form, but I can not seem to locate how to repair the 2 issues.
2 issues: Rear Wiper & Rear Hatch button:
1st issue:
Rear Wiper – is not working. The rear fluid Dispiser works and fluid comes out, but the wiper does not activate.
I checked the fuse, & it's good.
2nd Issue:
Dash release switch / Inside-Rear Hatch Button –
I use to have to push the Dash Realease rear-button a few times, to open the rear hatch. The inside rear hatch-button / Dash release switch, is no longer working to open the Rear Hatch Button.
I can open the rear hatch with the car Key or with the electric key fob.
Any advise/ guidance on the repair, with picture instructions, would be great!
I appreciate it.
herenow is offline
Old 11-05-2012, 07:10 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Check your wiring that runs through the umbilical into the hatch, this has been a problem with some in the past. You may have to repair/replace the wire.
Good Luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 11-13-2012, 03:27 PM   #3
herenow
Fan#: 105707
Points 333, Level 6
1st issue: Resolved =
Rear Wiper :
Purched a new rear wiper motor, installed... and it works now.
Repair time: basic 20 min replacement.. easy.
1st remove Nut Bolt from wiper on the outside hatch window.
2nd:
Inside Hatch / 4 plactic bolts to remove hatch cover /
3 bolts to remove the motor, disconnect plug, and plug in new Rear Motor.
2nd Issue: Resolved :
Resolution: Bought a new Trunk Button from Dealership $26$, plugged it, and trunk pops open.
REpair time: 5 mins. to take the dash cover off, a simply disconnect and plug in the new Trunk Switch.
herenow is offline
