Bad ground?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-04-2012, 08:50 PM   #1
drifterboyE3
Fan#: 102539
What I Drive: 01 zx3 03 explorer RIP ESCORT LX-E
FF Reputation: 1 drifterboyE3 Good Standing Member
Bad ground??
Hey guys just installed my subs and I have a hmmming noise that changes with the rpms. I have my rcas run down the passanger side threshold and behind the rear panels(zx3) and my power and remote is run under the drives side threshold. And I'm grounded at the lower bolt on the drivers side rear seat mount. I used a wire brush to scrape paint but do you think I could still have a bad ground? Any advice would help thanks
drifterboyE3 is offline
Old 11-04-2012, 08:52 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Welcome to the forum
Definitely sounds like you have a bad ground. Try moving the ground to a different location and see if that resolves the problem.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 11-04-2012, 08:57 PM   #3
drifterboyE3
Fan#: 102539
Where would you suggest. The person before me had subs and already had one ground wire under the rear seat but that yielded the same results
Old 11-04-2012, 09:01 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
I dunno, I actually grounded mine in the same spot as y'all now that I think about it. You may want to check all your grounds underneath the hood and make sure the battery and the motor are properly grounded and getting a good connection. Also depending on what car you have some have little resistors or noise isolators that are supposed to the do the same thing. I've replaced mine on my focus before though the noise it let through was very small and almost unnoticeable.
Moderator for
Technical Chat
Old 11-04-2012, 09:39 PM   #5
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
Points 4,176, Level 41
Points: 4,176, Level: 41 Points: 4,176, Level: 41 Points: 4,176, Level: 41
Level Up 13% Completed
FF Reputation: 3 sam fisher Good Standing Member
i grounded in the trunk under the car . at first i just used sheet metal screws , but later on i drilled a hole and bolted the mofo in lol.
Sent from my N860 using FF Mobile
sam fisher is offline
Old 11-05-2012, 12:02 AM   #6
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
the seat belt bolt has paint on it to. get the paint off of the bottom side of the bolt and try that.
hn155: Rockford punch pro speakers, t400.4 deh 80prs, full audio build to come. working towards 175hp n/a, simple but fun.
alaskanzx5 is online now
Old 11-05-2012, 02:04 AM   #7
Now534
Now534's Avatar
Fan#: 76549
What I Drive: 2013 Tuxedo Black ST2
Points 1,794, Level 24
Points: 1,794, Level: 24 Points: 1,794, Level: 24 Points: 1,794, Level: 24
Level Up 94% Completed
FF Reputation: 6 Now534 Good Standing Member
What do you have for a deck? Pioneers (i know some older models do this not sure on the newer models) have a Pico Fuse internally that when it blows will create engine noise through the RCA's. Easy solution to this was to wrap a wire around the plug on the RCA out (then plug the rca in to the back of the radio) then take the other side of the wire and wrap it around a screw in the back of the radio (pick one there are a few).
Now534 is offline
Old 11-05-2012, 05:07 PM   #8
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,786, Level 54
Points: 6,786, Level: 54 Points: 6,786, Level: 54 Points: 6,786, Level: 54
Level Up 18% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Buy-Sell-Trade Rating: (23)
^This
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-06-2012, 08:46 AM   #9
drifterboyE3
Fan#: 102539
It's a deh3900mp I believe. And yes I had that problem before wires touched and blew the ground. So I got a new deck(same one) and that solved the problem. It's just now that I put them in the focus. They were in an escort
Old 11-06-2012, 08:59 AM   #10
Now534
Now534's Avatar
Fan#: 76549
It's worth a try to fix. Its easy if you have scraps laying around
Sent from my SCH-I535 using FF Mobile
Now534 is offline
