2005 ford focus 2L zxw air filter question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2012, 02:15 PM   #1
jones81
Fan#: 104961
What I Drive: 2005 focus wagon, 2.o duratec
FF Reputation: 1 jones81 Good Standing Member
i did some reading and im not too interested in a full replacement of my air filter assembly, however i read people say they installed a k&n drop in filter for this car. Are they referring to a cone shaped filter attached to the maf tube or a rectangular filter fitting into the existing air box. If its the rectangle type is there a part number from k&n i can get please. thanks
Here's some of the projects i have done on this car since purchasing with a little help from this site.
-passenger engine mount (huge difference, took out the vibration)
-valve cover gasket ( had oil around my spark plugs)
- driver side seat warmer switch stopped working
jones81 is offline
Old 11-03-2012, 02:40 PM   #2
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
There is no drop in filter per say for your cars setup. However like you said some people have taken half of the stock setup out and put a cone filter on the bottom of the MAF tube (i believe you have to cut it as well) to make a CAI of sorts.
jetrinka is offline
Old 11-05-2012, 09:56 PM   #3
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 VillageT Good Standing Member
What is your Mileage?
I had the same issue with my 2005 ZX3. I had a 150K miles and the gauge was still in the green but I new I had to replace it.
If yours has under a 100K and the gauge is still green I wouldn't worry about it for a while. I saw no real degradation in fuel economy.
I ended up putting a FS CAI (long tube) system on it and am very pleased.
Hope this helps?
VillageT is offline
Old 11-06-2012, 06:52 PM   #4
bones33
Fan#: 105414
What I Drive: '05 Silver ST
Points 378, Level 7
Points: 378, Level: 7 Points: 378, Level: 7 Points: 378, Level: 7
Level Up 56% Completed
FF Reputation: 1 bones33 Good Standing Member
The stock air filter pulls in air from a very clean location so they last a long time. The cone filter attaches directly to the tube going down that has the MAF sensor in it. No cutting necessary. You can see what I mean easily by getting under the car and looking. I warmed the cone filter end so it would stretch just a little and a 3" I.D filter fit easily.
I should note that at 121,000 miles my air filter didn' look all that dirty, peering into the inlet side. Blowing into the filter housing the direction air would flow, there was quite a bit of restriction. The indicator was still in the green.
As far as I know there is no (reasonably priced) replacement air filter unit other than the cone filter replacement.
Thinking more about this, I believe the stock filter housing is made of ABS plastic. The same stuff black plumbing pipe, and it's glue, is made of. Replacing the filter MAY POSSIBLY be done this way: Cracking the stock filter housing apart and removing the stock filter media. Securely gluing a short 1" section of 3" ABS pipe (3.5" O.D) to the inside of the outlet of the stock box. Install cone filter onto the glued in pipe when cured. Would take some fiddling to get the right cut of pipe and filter combination to fit inside the box. I would also glue in some reinforcement plastic to this joint. Assemble both halves of the stock box back together and re-install the complete system.
This is just an untested idea as far as I know. If it works it would look and sound very nearly stock, but flow like an aftermarket. Also, as I said it pulls air from a very clean area of the car, so the filter should last a long time between cleanings.
bones33 is offline
