ddm tuning - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2012, 06:03 PM   #11
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
Points 8,314, Level 61
Points: 8,314, Level: 61 Points: 8,314, Level: 61 Points: 8,314, Level: 61
Level Up 55% Completed
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
there has to be. unless people wouldn't be doing it lol. i'm such a noob at hid's i wouldn't know where to start.
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 11-03-2012, 06:24 PM   #12
jmiller_1974
Flipping Rockstar
Fan#: 57165
What I Drive: Black 02 SVT #2998
FF Reputation: 28 jmiller_1974 Great Standing Member
Buy-Sell-Trade Rating: (14)
Just order the kit with the bulb size you want. It should come complete with ignitors(goes bulb>ignitor>plug), which should plug right in to your original wiring harness. That's how I've done it in the past. Hope that helps some.
dreamspeed
jmiller_1974 is offline
Old 11-03-2012, 06:47 PM   #13
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
just for clarification (because i need clarification).
buy the bulb i want
everything else will go from there?
indy_11 is offline
Old 11-03-2012, 06:50 PM   #14
jmiller_1974
Flipping Rockstar
Fan#: 57165
Basically, yeah. It was plug n play both times I've done it. Also, a significant amount of bulb plugs are the same, in case you get the wrong ones and need to buy different, separate bulbs. Just be sure to visually verify that they are the same, or you might end up with 2 hid kits and 3 sets of bulbs.(been there)
Key here is to be sure to specify which bulb size you need when ordering, or you may end up wi h1, which seems to be the standard aftermarket bulb size.
dreamspeed
Old 11-03-2012, 06:59 PM   #15
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
and that is the kind of answer i'm looking for. not some comment that won't help me. appreciate it. rep added
indy_11 is offline
Old 11-03-2012, 08:58 PM   #16
Baldurs390
Baldurs390's Avatar
Fan#: 86071
What I Drive: 2009 black ses
Points 3,739, Level 38
Points: 3,739, Level: 38 Points: 3,739, Level: 38 Points: 3,739, Level: 38
Level Up 60% Completed
FF Reputation: 4 Baldurs390 Good Standing Member
i have a full 6000k 55 watt ddm tuning kit would you like a photo?
FRPPFSWERKSDDMMassiveTruBenz
Baldurs390 is offline
Old 11-03-2012, 11:45 PM   #17
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
I have heard mixed reviews on DDM. Like said before some orders have taken 2 months to be delivered which is crap.
If you want a high quality AC digital ballast (non flickering) at a good price and want it in your hands in 3 days order it from my r6 forum site sponsor.
$55 for a single beam kit, $75 for a dual. He will take care of you if you have an issue but with kits in 6 different cars and bikes I have not had an issue yet. One kit is 1.5 years old!
These are not the cheap ebay Xentec, they are the higher end better ballast versions!
I am actually ordering extra bulbs from him right now, because I want to put 5000k in my new retrofit :)
http://aggracing.com/store/index.php...&product_id=73
A7xschecter6661 is offline
Old 11-04-2012, 01:18 AM   #18
mysticfocus
Fan#: 78635
What I Drive: 2011 Blue Flame Metallic SES
FF Reputation: 1 mysticfocus Good Standing Member
I have the 35 watt bulbs in my headlights and fogs going on almost 2 years straight and the only problem i have had is the ground on one wire pulled loose somehow and i had to solderer it again but other than that great!!
SES #003
mysticfocus is offline
Old 11-04-2012, 01:32 AM   #19
Barrow88
Barrow88's Avatar
Fan#: 91009
What I Drive: 10' Black SES, 02' Boosted ZX3
Points 964, Level 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Level Up 64% Completed
FF Reputation: 4 Barrow88 Good Standing Member
Ive never had a problem with DDM I had their kit before I retrofitted to Morimoto MiniH1 projectors. I had their raptor kit in my old car when I sold it never had a problem and I current have them in my motorcycle going on 1.5 - 2 years with no problems.
There are two ways to do this:
1.)One way is that you have to purchase a relay harness that has a connector that goes to one of the factory H13 connectors then into the relay which then separates into wires for both ballasts which then you connect to the ballast then you connect the HID bulb to the AMP connectors coming from the ballast (easiest way but you have to buy a H13 relay harness with your H9 HID kit if you are buying them for the Eagle Eye projectors).
2.)Sometimes they don't come with connectors just male spade terminals (like my motorcycle kit), or you pull the pins on the connector it comes with, then you just plug them into the factory connector (H13 in this case) making sure to get the polarity right (just plug them in, connect all of the other connectors, & bulb and test to see if it comes on if it doesn't just swap the spade connectors and re-test if it still doesn't work check all other connections and re-test) then you would have to use some electrical tape to seal up the connection.
Either way its a fairly easy install but that might just be me because I've hooked up so many kits lol. Im working till 5pm CST tomorrow but I might be able to take some pics tomorrow to help out
'10 SES
Build Thread: http://www.focusfanatics.com/forum/showthread.php?t=321737
'02 ZX3
Build Thread: Already Built... For Now
Barrow88 is offline
Old 11-04-2012, 07:11 PM   #20
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,349, Level 20
Points: 1,349, Level: 20 Points: 1,349, Level: 20 Points: 1,349, Level: 20
Level Up 49% Completed
Forum Activity 12%
FF Reputation: 1 popwarhomie Good Standing Member
I would never buy DDM again.
I only run Morimoto ballast and bulbs.
I ordered a DDM kit for my mothers car. Flickering, long warm ups, bulbs would fail to ignite.
I have 2 morimoto kits on my truck, 1 on my car and now 1 on my mothers car.
2010 Focus coupe 5 speed
Projector retrofit/LED tails/ Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/HDC3 18"s walled/ Juicebox G31/ DC power 270XP Alt/
94 Lightning
A lot of mods.
popwarhomie is offline
