Camshaft specs...FINALLY!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-02-2012, 03:51 PM   #1
jlawlax1344
Fan#: 99464
What I Drive: 2003-CD Silver-SPI-5spd
Points 197, Level 3
Points: 197, Level: 3 Points: 197, Level: 3 Points: 197, Level: 3
Level Up 94% Completed
FF Reputation: 1 jlawlax1344 Good Standing Member
To anyone curious or trying to replace or get an aftermarket cam for their SPI, i did some research and talked to some buddies in the machine shop and finally have specs for the cam!!!
at .050 lift it has a duration of 186 degrees for the intake and exhaust and it has 134 degrees of lobe separation.
Aftermarket options: the only ones i really found are from http://www.cranecams.com/view.php?s_id=5
then select the 74-87 2000cc-2300cc SOHC engine and viola!!!!!
you now can order cams from a basic upgrade to major head work and swap for mechanical roller cams for drag racing (yes it sounds weird that this is the engine, but talking to friends that have worked on this engine and getting specs and talking to crane cams, these should fit perfectly into out engine with the obvious springs, retainers, lifters, and keepers upgraded!!!!)
2 12" rockford fosgate subs,1500w Hifonics amp, throttle spacer, performance chip, FSWerks 2.5" race exhaust, custom CAI w/Spectre 10.5x6 filter Blue leds all around pulsating in the trunk, smoked taillights and turn signals
jlawlax1344 is offline
Old 11-07-2012, 04:12 AM   #2
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Unless I am crazy that is a nonsensical lobe separation number, the range is generally from 100 or so to around 115...................
You have also picked wrong motor in Crane catalog, that SOHC is the old Pinto-Mustang II engine for RWD. Totally different engine with no common parts. Note the cam followers pictured on right hand page, The SPI uses rocker arms and lifters, not followers and lash adjusters. I used to work on those engines, I assure you those parts do not fit the SPI........
amc49 is offline
