??? Which to buy 05 or 07 ??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 11-01-2012, 09:00 PM   #1
RRTAYLOR
Fan#: 105546
What I Drive: 2005 Silver zx3
FF Reputation: 1 RRTAYLOR Good Standing Member
Hello,
I am going to buy my first focus on monday.
Either an 2005 stick or a 2007 auto.
Both cars are ZX3
Both cars have the 2.0 motor
I am wondering if I should be aware of anything, good, bad?
Reasons to buy one over the other?
Any information is appreciated.
Thank you
RRTAYLOR is offline
Old 11-01-2012, 09:04 PM   #2
sjdwales
Wales!!
sjdwales's Avatar
Fan#: 46854
What I Drive: 11 mustang
Points 15,707, Level 80
Points: 15,707, Level: 80 Points: 15,707, Level: 80 Points: 15,707, Level: 80
Level Up 72% Completed
FF Reputation: 13 sjdwales Great Standing Member
Buy-Sell-Trade Rating: (26)
depends on if u want manual or auto? if your thinking of going manual just buy it. u will be regretting later otherwise.
No longer drives a focus, WTF?
sjdwales is offline
Old 11-01-2012, 09:16 PM   #3
thisiskevin
thisiskevin's Avatar
Fan#: 95067
What I Drive: 2012 Focus SE Sport 5MT
Points 198, Level 3
Points: 198, Level: 3 Points: 198, Level: 3 Points: 198, Level: 3
Level Up 96% Completed
FF Reputation: 2 thisiskevin Good Standing Member
Bingo. How many miles on each of them?
12' Focus SE Sport | 98' Mystique GS
| kevinmoranphotography.com | ╠╬╝
thisiskevin is offline
Old 11-01-2012, 09:18 PM   #4
RRTAYLOR
Fan#: 105546
The 05 has 38k
The 07 55k
RRTAYLOR is offline
Old 11-02-2012, 03:45 AM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,163, Level 74
Points: 13,163, Level: 74 Points: 13,163, Level: 74 Points: 13,163, Level: 74
Level Up 79% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Hands down get the 05.
zetecDon is online now
Old 11-02-2012, 06:10 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
There are a few differences between the 05 and 07. 05 was the first year for the Duratec 2.0 engine used in both. If you'll look closely, the power steering pump reservoir is in a different position in the 05 than in the 07. One you can't see is that the 05 has a tubular exhaust manifold as compared to the 07 having a cast manifold. Both are what's called mani-cats since the first catalytic converter is built into the exhaust manifold.
The only problems are that the 05 had a larger hole in the TB so it would sometimes make the fuel/air mix too lean to start. This can be embarrassing, but causes no damage. What will happen is that you'll crank the engine, and it won't start the first time. This won't happen every time, but it will happen. Not all 05s experience this problem. What I do is crank for 1 sec, if it doesn't start, turn the key off, then crank again and it always starts immediately.
I'd get the 05 also, but remember- replacing a clutch in this car is not as inexpensive as, for example, a Chevy Cavalier. Our clutches use a dual mass flywheel that is actually 2 parts separated by a large spring. This takes out some of the harshness when the clutch engages the trans and engine, but it must be replaced when the clutch is replaced making the parts expensive for a clutch job. As you're going along you should save about $1200 somewhere just for parts. Figure about $500 for a clutch, $400 for a flywheel, $30 for flywheel bolts (very important), and $70 for a slave cylinder. Another $200 is in there for misc like brake fluid and a vacuum bleeder for bleeding the clutch down. Single mass flywheels are available to replace the DMF if you want something that might not have to be replaced every time. If anyone tells you that the DMF doesn't have to be replaced, then you should seek another mechanic. Research DMFs online, and you'll see what the truth is.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-02-2012, 07:57 AM   #7
boardgeneration
boardgeneration's Avatar
Fan#: 97319
What I Drive: Redline 13 Dodge Dart Rallye
FF Reputation: 1 boardgeneration Good Standing Member
Love my 05zx3 5 speed. No major problems yet. Did change motor mounts. Passenger side was destroyed.
Changing the alternator and upgrading the big 3 next week.
By next summer ill be installing a header n 2.5" exhaust. I think my exhaust mani has a crack in it.
I'd say go for the 05 for two reasons. Low miles as u stated and the MT is so fun to drive.
Just adding CAI makes it a bit more snappy too.
“Who you are speaks so loudly I can't hear what you're saying.” -Ralph Waldo Emerson.
boardgeneration is offline
Old 11-02-2012, 10:50 AM   #8
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,882, Level 59
Points: 7,882, Level: 59 Points: 7,882, Level: 59 Points: 7,882, Level: 59
Level Up 66% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Does the 07 have the SAP package on it ?
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 11-02-2012, 12:27 PM   #9
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 05 Slowbaru Outback
FF Reputation: 2 Kevastator Good Standing Member
05!!! Less miles is always better, and yeah the manual trans too
College Yo
[Rally Revolution #7]
ASPECT Motorsports
Kevastator is offline
Old 11-02-2012, 06:51 PM   #10
RRTAYLOR
Fan#: 105546
Thank You
Thank you all very much for your input it is greatly appreciated. As I staed this is my first focus and I know nothing about these cars. I can rebuild an old El camino or mustang in my sleep. I weld power turbines for a living, but these little cars with all their computers and such confuse me.
Again thank you, I will get the 05.
RRTAYLOR is offline
