CAI causing issues... - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 11-01-2012, 03:04 PM   #1
miscreant
miscreant's Avatar
Fan#: 105138
What I Drive: 2010 Silver SES
FF Reputation: 1 miscreant Good Standing Member
Hey guys,
Got a lovely 2010 SES a few months ago and it's such a beauty that I wanted to start modifying it. Anyways I got a K&N 69 Typhoon CAI (the one their website says is for the 2010 SES) and install went great. Car sounded great, felt a little more pick up, no problems.
That was a week and a half ago, then a few days ago at around 1500 rpm it seems to judder and won't switch overinto higher gear (automatic) unless I floor it and let the overdrive kick in and it still doesn't sound quite right.
What do you think, is this a transmission problem that just cropped up at the same time or is the CAI messing with stuff? I haven't gotten a flasher yet, was gonna wait til I installed the exhuast.
I did call K&N and the lady I talked to seemed to think I got the wrong CAI, that because I had a TiVCT engine K&N didn't have one. Now I know I am knew to this, but I'm pretty damn sure I have a normal Duratec 2.0L.
miscreant is offline
Old 11-01-2012, 03:22 PM   #2
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 27,874, Level 98
Points: 27,874, Level: 98 Points: 27,874, Level: 98 Points: 27,874, Level: 98
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
yeah you dont have a tivct engine.
did you leave the battery disconnected for 10-15 minutes to reset the comp?
make sure everythings tight. if you want to see if its tranny related just swap back to the stock setup for a few days to test.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 11-01-2012, 03:34 PM   #3
miscreant
miscreant's Avatar
Fan#: 105138
I kept it disconnected while I was installing it, which took an hour or so. Ahh I see what she was talking about, she didn't say T-Vict, she said PZEV.
Old 11-02-2012, 12:07 AM   #4
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
it's happened before to alot of ppl on here. my focus is a manual but when i'm in a 3-5 and at a low rpm it starts to sputter. thats just the nature of not having a tune i suppose.
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 11-02-2012, 12:52 AM   #5
miscreant
miscreant's Avatar
Fan#: 105138
So tuning it, either getting it professionally done via Tom, or getting a flasher from say FSWERKS will help alleviate the problem?
Old 11-03-2012, 07:37 PM   #6
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Memory is a bit fuzzy here but wasn't there a difference between the 05-07 and 08-11 MAF tubes? Steedas SRI kit came with a removable insert of sorts for this reason?
K&N also had issues with their MAF tubes being off in diameter, throwing off the MAF reading a bit. Perhaps this issue is present with this intake as well?
I wouldn't think you would need a tune to deal with just an intake. You are not drastically changing anything from stock except a more direct, and free flowing path of airflow to the engine and the cars adaptive learning strategy should be more than able to compensate.
I would start by making sure everything is tight. Make sure the MAF is in the right way. If those conditions are met, I would pull the MAF out and look at the sensor wire in it and see if it has been contaminated by the filter oil. If its oiled too much, oil film can make its way onto this wire, bake on it and cause bad readings. Take some special MAF cleaner to it if you suspect its dirty at all.
jetrinka is offline
Old 11-04-2012, 01:28 AM   #7
miscreant
miscreant's Avatar
Fan#: 105138
When I e-mailed K&N the person that was helping me decided to send me an MAF harness that should work, so it sounds like she thought that was the issue too.
I had reset the ECM again and let it learn the idle trim again and it fixed the problem mostly, still does it a bit but not as bad. I'm going to install that MAF harness and see if it does the trick.
Old 11-04-2012, 09:30 AM   #8
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
Forum Activity 3%
go with FSW. youll thank me
==1972 Skylark==
Buickboy is offline
Old 11-04-2012, 09:33 AM   #9
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
from the people i've talked to with tunes, they say their car runs fine. the people without tunes have this issue. i even had it when i took the airbox resonator off. i wish i could get a tune so i could tell you if that is the case, but i'm low on funds
indy_11 is offline
Old 11-04-2012, 11:25 PM   #10
miscreant
miscreant's Avatar
Fan#: 105138
That causes me a dilemma then....get a flasher and tune, or get an exhaust...
