#71 | ||||
Sonic MK3 Crew #06
Technically from version 5 of the 12 owners guide pg. 245:
As long as it doesn't tell you the actual pressures its pretty much useless for monitoring anything except a catastrophic failure.
Moderator for: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, Great Lakes Fanatics |
#72 | ||||
Direct systems measure the actual pressure for each tire, not pressure differentials between tires. |
#73 | ||||
Sonic MK3 Crew #06
Ergo if it cared about absolute pressure being low on one or more tires at the same time should have gone off with them all equally too low, but that's not what it did. That could be indicative of a failure in programming or an RF interference however as it should have gone off, but others have also reported that either with new sensors that weren't programmed, or without sensors sometimes it still takes a long long time for it to error out. Does seem to be a malfunctioning system per the service manual, but not like Ford would actually fix anything at all ever. Quote:
#74 | ||||
For example, if the dealer said that the tires were at 28 PSI, does it mean that all four tires had an exact pressure of 28.000 PSI? |
#75 | ||||
I have a small garage (I don't even park in it, I park in front of it) so I keep my extra set of tires in the shed in the back corner of my yard, away from where I park. I'm running back to dealership on Saturday so I'll confirm either way but as others have said, if they self-program why do they sell the tool to reset them (and why did they have to reset them the last two times they swapped my tires)?
. .......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you. |
#76 | ||||
Well, Ford is correct, you do NOT need to "retrain" new sensors to your car.. They do "auto train" or whatever you want to call it. All three of our Fords have the TPMS system (all, including our F150 use the valve stem style), and we have seperate winter rims and tires for all (we live in a heavy snow belt area, winter tires are a must). We bought our winter rim/sensor combo from the dealer, but, I assure you, in the last three seasons, I've switched over my own rims each season in my garage and the dash display resets within 500m of driving (less than a minute). No visit to the dealer needed, ever. I don't know where this rumor started about having to "train" new sensors, etc. I will say that my neighbor has a couple of Honda's and a Dodge truck, and he says that he has to have the sensors trained, so, they must use a different system. I know his CRV uses the "band style" sensors which are expensive and a pain to install.
Also, another thing to note, since some have brought it up here, the trick of just putting a summer rim/tire in the back of your car, etc. To turn out the warning in your dash, that will only work if you keep the wheel moving once and a while, since, the sensors will go to "sleep" after so many minutes of not moving (preserves battery life). Just saying.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue 2012 Escape Limited w/park assist 2010 F150 Supercrew XTR 5.4 4x4 2008 Kawasaki Concours 14 (street) 2008 Kawasaki ZX10R (track only) |
#77 | ||||
Looking at the NHTSA there seems to be conflicting info. One spot it states that the system should indicate when any tire including all four drops 25%. In another spot on the site it seems to be referencing a table that states 20 psi is the safety floor. Although it does state
"Overall, we feel that the 25 percent threshold adequately captures the circumstances at which low tire pressure becomes a safety issue. We also believe that this level would be acceptable to most drivers and would not be considered a nuisance to the point that it would be ignored by large numbers of drivers. We also believe there is no reason to examine higher thresholds (e.g.,� a 30 percent threshold), which would provide fewer benefits for similar costs" http://www.nhtsa.gov/cars/rules/ruli...part1-2.html#1 |
#79 | ||||
#80 | ||||
Tell me this, if you have a tire sensor telling you that there's low pressure in a tire, you're going to keep driving without physically getting out to look at it? I know I'd get out and make a judgement call on it and inspect the other tires to make sure it's only one. It's a good idea to have the reset tool, but ford also does it for free. Meh
'12 Focus Ti HB SGM - Maxxis Victra on KMC RockStar 18x8" |
| Thread Tools | |
| Display Modes | |
