JRSC just installed....car will turn over but won't idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2012, 06:06 PM   #1
mj22
Fan#: 32067
What I Drive: 2003 silver 2.0. zetec
FF Reputation: 1 mj22 Good Standing Member
Unhappy JRSC just installed....car will turn over but won't idle
Hey Everyone,
I have just finished up installing a JRSC kit on my car.
I went to start the car for the first time this morning and have run into a problem.
When I start the car it turns over as usual with the indicated revs jumping to 1500 rpm or so and then they quickly drop down as used to be the case when starting the car. My problem is the revs continue to drop quickly until the car stalls. It is not as if the car is spluttering and the revs are slowly dropping until it stalls, they drop quickly.
I tried to correct the problem by applying some throttle when I start the car. This made no difference. While I could get the revs to climb a little higher at start up by applying about 10% throttle, no amount of throttle will stop the rpm dropping - if anything applying the throttle seems to make the car stall more quickly.
Can anyone offer their thoughts on what they think may be the problem?
I will do the usual checks for vacuum leaks once I am home tonight however given how quickly it is stalling this seems like it may not be the problem. Most people seem to just have a really rough idle with vac leaks. Could be a massive leak somewhere
Is it possible it could be the tune? I have an Xcal 3 and only have a base tune loaded on their which the tuning will be adjusting once the car is running. I've heard mention of custom tunes not supplying enough fuel for start?
Any help would be great!
Thanks
Mike
mj22 is offline
Old 10-30-2012, 06:36 PM   #2
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,593, Level 43
Points: 4,593, Level: 43 Points: 4,593, Level: 43 Points: 4,593, Level: 43
Level Up 22% Completed
FF Reputation: 28 ah1f39 Great Standing Member
Sounds like the fuel pump isn't switching from start to run. Check the fuel system. Relays, fuse, lines...ect.
ah1f39 is offline
Old 10-30-2012, 07:54 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,271, Level 100
Points: 51,271, Level: 100 Points: 51,271, Level: 100 Points: 51,271, Level: 100
Level Up 0% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Buy-Sell-Trade Rating: (28)
A base tune is just that a base tune , you need to get your car tuned properly to get it to run right ,
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 10-30-2012, 08:42 PM   #4
mj22
Fan#: 32067
Thanks Tom. I appreciate what you are saying.
I'm chasing advice as to what I should be looking at myself prior to discussing the problem with the tuner.
I will definitely check the fuel system once I am home tonight.
mj22 is offline
Old 10-30-2012, 09:24 PM   #5
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
is your maf installed correctly?
idle air control set correctly?
BigRed03 is offline
Old 11-01-2012, 06:22 AM   #6
mj22
Fan#: 32067
Hey again Everyone
So I did a datalog and the car is reading 0 fuel rail psi. So I make the assumption this is a fueling problem.
The fuel system appears to prime just fine. Possibly this is what is providing me sufficient fuel to kick the car over and let it run for couple of seconds.
I also took the return line of the fuel rail (Australian Focus have a return fuel system) and attached a hose to the return feed for the fuel rail then to a bucket. Turned the ignition key and had plenty of fuel was coming through the fuel rail as the fuel system ws attempting to prime.
My question now. What does everyone think the likely cause is for the fuel rail to be reading 0 psi?
I have checked all the fuses and relaya (switched the relays around with others of the same type), all of the various connectors are connected/clipped up properly.
Could it be an issue with the vacuum line between the fuel pressure sensor and intake manifold? However I assume the fuel pressure sensor is seeing vacuum on start up as it is t'd into the same line as my boost gauge which shows vacuum on start up. I followed the vacuum line configuration advised by OJ as mentioned discussed in a couple of threads over on FJ
Alternately could this be tune related? ie. tune is setup for different injectors by error or something along those lines?
Anything else anyone can think would be causing the problem?
Again any help would be great as I am very keen to get the car back on the road.
Thanks,
Mike
mj22 is offline
Old 11-01-2012, 11:33 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 22%
Do you have fuel psi why cranking ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 11-01-2012, 11:37 AM   #8
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
That's exactly what I said the problem was. You need to recheck your vacum lines and make sure that they are set up the way JR sugested.
When you engine fires and runs it creates vacum wich makes the fuel pump relay switch to the "run" circuit.
If it was an injector mismatch problem it would run but would have a rich/lean mixture.
ah1f39 is offline
Old 11-01-2012, 04:42 PM   #9
mj22
Fan#: 32067
Hey Tom
The car reads 0 fuel psi even when cranking.
However, like I said there is definetely some fuel there to get it started.
I also checked a datalog that I completed prior to installing the JRSC kit and it was reading fuel pressure. ie. the datalogging does work with Australian delivered focus.
If you have anymore thoughts that would be great.
Thanks!
mj22 is offline
Old 11-01-2012, 06:17 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 22%
Im not sure I understand what your saying , the Focus will start and idle with no problem even with no Vac lines hooked to anything ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
