zetec water pump removal - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-27-2012, 12:03 PM   #1
finalfantasy
Fan#: 86774
What I Drive: 2001 SE
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
Forum Activity 8%
FF Reputation: 1 finalfantasy Good Standing Member
does anyone know whether those folks who DIDNT have to drop their engine to get the pump out had an aftermarket water pump?
Someone said they had a "rounded" pump or something?
finalfantasy is offline
Old 10-27-2012, 04:05 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
You don't have to completely drop it but you have to take the pass side engine mount lose and lower that side of the engine
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 10-27-2012, 04:12 PM   #3
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
Level Up 78% Completed
FF Reputation: 2 150mphzetec Good Standing Member
I just did this. It takes some wiggling, but it can be done without dropping the engine
150mphzetec is offline
Old 10-27-2012, 07:42 PM   #4
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,065, Level 34
Points: 3,065, Level: 34 Points: 3,065, Level: 34 Points: 3,065, Level: 34
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Remove torque mount (underneath)
Make alignment marks on passenger and drivers side motor mounts.
Loosen 4 bolts on drivers side mount so engine can move sideways a little.
Put jack and block of wood under oil pan.
Remove passenger side motor mount.
Remove 4 bolts holding AC compressor to engine, slowly let it down and let it hang by hoses.
Lever engine towards drivers side of engine bay with 2x4.
The removal of the AC compressor gets you a little bit more working room, and also access to the top hose clamp on the engine radiator hose.... (replace now while your doing the water pump)
Ed
emsvitil is offline
Old 10-27-2012, 07:44 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (11)
There is no need to remove the a/c compressor if your just replacing the water pump itself. Now if your replacing the water pump housing then yes it would be a good idea to remove it to help free up room though I never did.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 10-27-2012, 07:53 PM   #6
emsvitil
Fan#: 50210
Forum Activity 2%
I've done it both ways....
Took much less time (and much less agravation) with the AC compressor out of the way (even including the time to drop the AC compressor). It's only 4 bolts.....
Plus that's the only way I could get to the radiator hose clamp.
Ed
emsvitil is offline
Old 10-27-2012, 07:54 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
That's probably what I should have done instead of cussing and cramping my hand up doing it lol
But I only needed to remove the water pump housing one time due to me prying the stuck on water pump off and making the housing to block seal leak.
Oh and a tip to others don't run strait water or the same thing will happen to you. The insides of the motor and the pump get corroded and scaled up which will make removing the water pump very difficult if not damn near impossible if ran like that for years.
Moderator for
Technical Chat
Old 10-27-2012, 07:59 PM   #8
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,099, Level 67
Points: 10,099, Level: 67 Points: 10,099, Level: 67 Points: 10,099, Level: 67
Level Up 13% Completed
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (41)
cool sounds like alot of fun lol
pasta is online now
Old 10-27-2012, 08:30 PM   #9
emsvitil
Fan#: 50210
Forum Activity 2%
Also for some reason it's easier to get out if you flip it in place so that the pulley flange is in the water pump housing cavity and the impeller is on the outside before you start trying to get it out................
Ed
emsvitil is offline
