2004 LX 2.0 SPI tries to start but won"t - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-27-2012, 12:45 PM   #11
bigrigjim
Fan#: 105352
What I Drive: 2004 silver lx
FF Reputation: 1 bigrigjim Good Standing Member
i bought the coil a few months back when i did a tune up and never put it on. has spark and fuel pressure was running fine when shut off wouldn't start back.
bigrigjim is offline
Old 10-27-2012, 12:50 PM   #12
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
If you've confirmed spark and fuel properly, then time to move on. Buy yourself a compression tester from the local auto parts store - $30.
If your compression shows low readings or readings are "lopsided" then timing is most likely the problem and the timing belt may have shed a few teeth and slipped. If you're not so lucky, one cylinder may read very low due to valve seat problems.
Crank position sensor is fine is you have spark.
IACV problems would result in an inability to idle consistently, not a no-start condition.
BC_ZX3 is offline
Old 10-27-2012, 12:54 PM   #13
bigrigjim
Fan#: 105352
ok would that happen without any warning?? Was running fine, pulled in to store parking lot turned it off, went inside for 10 minutes, came out and it wouldnt start.
Old 10-27-2012, 12:58 PM   #14
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,658, Level 100
Points: 35,658, Level: 100 Points: 35,658, Level: 100 Points: 35,658, Level: 100
Level Up 0% Completed
Forum Activity 8%
Yes.
TheGlassMaker is online now
Old 10-27-2012, 01:02 PM   #15
bigrigjim
Fan#: 105352
ok thanks very much time to buy a compression gauge and timing belt and tenisoner and go out and play in the rain. not a good way to spend the weekend
Old 10-27-2012, 01:03 PM   #16
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 8%
I can't find the thread, but one guy just went out to start his car for work and it was over.
But here is this.
http://www.focusfanatics.com/forum/s...ped+valve+seat
Old 10-27-2012, 01:05 PM   #17
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
It's possible. Another poster on FF recently had the timing belt go on their car (not a Focus) after coming to a stop at a light.
And just to confirm: Engine spins freely (sounds OK mechanically)?
What do the spark plug ends look like? Sooty and black or wet with fuel or?
BC_ZX3 is offline
Old 10-27-2012, 01:09 PM   #18
bigrigjim
Fan#: 105352
if it is a valve seat it should show up as loss of compression in one of the cylinder right???
Old 10-27-2012, 01:11 PM   #19
bigrigjim
Fan#: 105352
engine cranks normal plugs were damp with gas but clean, cleaned and replaced
Old 10-27-2012, 01:17 PM   #20
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
Yes.
BC_ZX3 is offline
