Fuel pump problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-27-2012, 08:48 AM   #1
ehancock
un1corn
ehancock's Avatar
Fan#: 53353
What I Drive: 2004 Twilight Blue D23 ZX5
FF Reputation: 14 ehancock Great Standing Member
Buy-Sell-Trade Rating: (7)
Fuel pump problems
I'll try and keep this short and sweet.
Car is a 2002 SE/Auto. The car has now sat for ~13 months. Ran perfect when parked. I undid some mods, put it back to stock including swapped the cat, reinstalled EGR accessories, swapped AC compressor, AC line, and installed a new battery. On crank the car turns over, starts, and runs very rough for ~10-20 seconds then dies. After it dies it will not start again. I let the car sit over night, tried it again in the morning and it did the same thing, ran for ~30 seconds and then stalled with the same problem.
This is what i have done to troubleshoot it. I know i have spark. Assuming it may be gas i dumped some fresh gas with some "Start!" and this did not help. I unplugged the fuel rail line and cranked and it didn't spray gas. Doesn't spray gas from line BEFORE the fuel filter either. I made sure to press down on the inertia switch in the kick panel just in case. Fuse is good, i'm not sure about the relay but i don't know how to test that. I do not hear the fuel pump prime when i turn the key on. I don't even recall hearing the fuel pump when it starts but i wasn't really listening either. Also using the cluster i can tell the car is not throwing any DTC.
What can i do to further diagnose this before i drop the tank and replace the pump? I know i need to test the relay. Is there any point in the wiring harness i can connect a 12V source to test the pump? Obviously i cannot reach the connector as it is between the tank and the floorboards. Any help would be greatly appreciated
ehancock is offline
Old 10-27-2012, 09:44 AM   #2
beat3rfocus
aint no shame
Fan#: 3178
What I Drive: Red 1990 Miata Hardtop
Points 15,226, Level 79
Points: 15,226, Level: 79 Points: 15,226, Level: 79 Points: 15,226, Level: 79
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 11 beat3rfocus Great Standing Member
Buy-Sell-Trade Rating: (9)
Check the wires under the seat from the wiring swap.
I sold my focus after 9 years.
beat3rfocus is offline
Old 10-27-2012, 10:01 AM   #3
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,610, Level 43
Points: 4,610, Level: 43 Points: 4,610, Level: 43 Points: 4,610, Level: 43
Level Up 30% Completed
Forum Activity 4%
FF Reputation: 28 ah1f39 Great Standing Member
E The 00-02 had fuel pump problems. Doubt it's the wires unless they got damaged some how. They were well wrapped and insulated.
The relay should make a clicking noise as it switches.
ah1f39 is offline
Old 10-27-2012, 10:26 AM   #4
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 23,065, Level 93
Points: 23,065, Level: 93 Points: 23,065, Level: 93 Points: 23,065, Level: 93
Level Up 72% Completed
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
Find the relay, then find another in the bay that is the same one. Swap them. See if that helps or if the other system controlled by the same relay now doesn't work with the swap. You'll eliminate the relay as a problem. There should be several of the same ones under the hood.
I can get you some relays from the yard if need be...
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is offline
Old 10-27-2012, 12:02 PM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
In case the inertia switch is bad for some reason- which is doubtful- unplug it, and use some wire to bridge the 2 points on the connector. That will bypass the inertia switch completely.
The fuel pump module is under the back seat on the passenger side. There's not a whole lot you can do here except check to see that there is 12v on the input side when the key is ON. The fuel pump connects to it on the side that goes through the floor.
Problems with the fuel sender might cause issues, but I'm unsure how to diagnose. I would expect a DTC from that one. I wouldn't expect a DTC from a bad fuel pump, or inertia switch.
Your start problem- runs for up to 30 seconds then dies- seems to me like the fuel system is allowing some fuel to get in the lines, then it when that runs out the engine dies. Since you've opened the lines up to air now- it might not do that again.
Um, for future reference, I don't recommend disconnecting fuel lines, and then cranking the engine to see if fuel comes out. I'm sorry I don't have pics, but I do have a friend who can tell you that the smallest spark you can't see from a bad spark plug wire will ignite that fuel and give you 3rd degree burns quicker than you can figure out how to put the flames out. He can also tell you how someone blasting an ABC extinguisher on you can give you lung problems even if it does stop the flames. Keep that stuff in mind next time you want to test fuel and use the electronic odometer trick to find fuel pressure- look for the reading [FP 111] in kpas. If you need to double check the fuel sensor for whatever reason, then get another under-hood fuel line and cut in a mechanical FP gauge.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-27-2012, 12:03 PM   #6
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
Forum Activity 4%
Worked fine after the swap till parked. Is compatible, it is the Zetec harness.
ah1f39 is offline
Old 10-27-2012, 12:07 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Let us know how the diagnosis goes so we can continue to help you. You're inspiring me to eventually write a "Safety First" How-To once we get done with some re-arranging. Don't feel bad, safety is now my job at work in an industrial chemical setting, so I think about that stuff a lot. Sometimes those "old fashioned" diagnostic ideas aren't as smart as you'd think. There's no sense in sticking your face up a horses butt to see what it's been eating when you can just wait for it to poop on the ground.
Be eclectic.
Old 10-27-2012, 05:56 PM   #8
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
The voltage to the pump works like the , the 12 volt hot is hot all the time so if you check the 12v + side it will show good
The Focus fuel pump works off a ground base and the ground is regulated so you would need to check both the + and the - side to confirm you have both at the fuel pump wiring after the fuel pump module
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 10-27-2012, 08:21 PM   #9
Davidt2169
Davidt2169's Avatar
Fan#: 104963
What I Drive: 2001 Black Zx3
FF Reputation: 1 Davidt2169 Good Standing Member
this is what i believe is my issue as well, it will start for a bit then die.
have you had it keep running for any amount of time? i had mine start but stutter while driving(accelerating and when getting on it) then would idle down and die at stops.
Davidt2169 is offline
Old 10-28-2012, 12:04 AM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
You need to do a datalog and stop guessing , a datalog will show fuel psi and in most cases show you whats wrong , do some datalogging
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
