Steeda Font & Rear Sway's - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2012, 03:12 PM   #41
cobie56
Fan#: 84403
Originally Posted by Sonic_HedgeHog View Post
Please explain, I did not realize the Ti was the epitome of handling for the Mk3
IMO, it handles better than the standard SEL set up...(minus the big turning radius) If u don't agree that's fine. Just reporting what i experience...no more , no less.
cobie56 is offline
Old 11-05-2012, 10:18 AM   #42
SteedaBrandon
Fan#: 96136
What I Drive: n/a
FF Reputation: 1 SteedaBrandon Good Standing Member
Originally Posted by cobie56 View Post
Hey all,, final update (well at least for now)
New tires def made a difference as i said above... Had Steeda's rsb installed this morning and it does make the car handle much better... Not to Ti standards, to be sure, but def better.. Corners flatter, better and/or sharper turn in (some of that no doubt due to the new tires), less push in taking sweepers and on/off ramps faster... Do feel the bumps a tad more but it's barely noticable -- very solid feeling.. The jiggle-ness of the rear suspension w/ the oem set up over multiple bumps is totally gone. Def feels as if there's more 'connection' with the pavement. So far, very happy w/ my investments.
tightened it all to 42 ft lbs of torque as advised and greased the hell out of the bushings... No squeeks or clunks or bangs or any noise at all.
Glad to hear you like your Steeda RSB!
SteedaBrandon is offline
Old 11-05-2012, 01:23 PM   #43
a351must2
Fan#: 87762
What I Drive: 2012 Focus Ti, 2011 Mustang GT
FF Reputation: 1 a351must2 Good Standing Member
Since I've had my Steeda RSB installed for almost a year now I thought I'd post again ... I have a Ti with the handling package.
1st, the car still has understeer with just the Steeda RSB installed. No worries of oversteer, just reduced understeer.
2nd, driving I90 through Idaho at 75 to 85mph around corners marked with 45mph caution signs felt significantly better than previously with the stock RSB. I'd hate to admit it, but it actually feels better than my 2011 Brembo Mustang does on the the same corners. I just drove the same route in the Mustang and it wasn't long before I started thinking about sway bars for it. Previously, the Mustang had felt way better than the Focus on that drive.
Can't say anything about whther or not actual grip in corners has improved, but confidence and "feel" definately has.
2012 Focus Ti Hatch, Blue Candy
2011 Mustang GT, Grabber Blue, 6spd
1978 Mustang II, 351W, Tremec 3550
1978 Mustang II, 2.3L Turbo, 5spd
a351must2 is offline
Old 11-05-2012, 03:39 PM   #44
jamnesta
Fan#: 93256
What I Drive: 2012 Titanium
FF Reputation: 2 jamnesta Good Standing Member
Most likely referring to Ti w/ handling package.
jamnesta is offline
Old 11-05-2012, 05:44 PM   #45
cobie56
Fan#: 84403
exactly! thank you.. at least someone understood what i meant.. i probably should have specified 'w/ handling pkg' but i guess i figured that was understood as w/o that pkg it's not much diff than the SEL suspension-wise.
cobie56 is offline
Old 11-05-2012, 05:59 PM   #46
awsimons
awsimons's Avatar
Fan#: 100921
What I Drive: Sonic Blue 2012 Ford Focus
FF Reputation: 1 awsimons Good Standing Member
I think Sonic meant that it's hard to believe that any OEM suspension setup is the absolute best that anyone will ever do for the mk3. I would tend to agree that aftermarket parts will currently or eventually out-perform an OEM setup, even if it is the highest end option from the factory.
Alan
2012 Ford Focus
Sonic Blue SE 5Dr
203A Package, 6 Speed Auto
Mods: Debadged, 30% LLumar CTX Tint, MS3 RMM, Steeda RSB
awsimons is offline
Old 11-05-2012, 06:07 PM   #47
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 124,710, Level 100
Points: 124,710, Level: 100 Points: 124,710, Level: 100 Points: 124,710, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Alan, thanks for the back up in that. You are correct in aftermarket vs OEM, but what I was really getting at is Cobie drives an SEL, not an SE Sport or Ti with handling pack. I just have a hard time saying those are perfection and what should be aspired to. The ST would be a better benchmark.
Cobie, I knew you meant "Handling pack" equipped.
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 11-28-2012, 11:27 AM   #48
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
Steeda FSB/RSB (MK3 Focus)
I purchased a Steeda RSB a while ago and recently heard groaning/squeaking from the rear so I pulled the bar off and relubed the bushings; anyone else have this? I called Steeda and told them about it and they seemed suprised.
http://www.steedafocus.com/parts/201...r-swaybar.html
While I was on the phone with them I discovered they have a FSB for the 2012's so I bought one; anyone have one and if so thoughts on it?
http://www.steedafocus.com/parts/201...t-swaybar.html
greg hazlett is offline
Old 11-28-2012, 11:58 AM   #49
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Poly bushings will squeak/groan after a while, even if you lube them well. I used the entire tube of silicone grease included with mine when I installed it, but it still groans in colder ambient temperatures. It's a tradeoff of having those stiff poly bushings vs. the quieter, softer rubber ones.
Hatch Nation #90
TboneZX3 is offline
Old 11-28-2012, 12:01 PM   #50
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I wouldn't recommend the FSB unless you decide to also install the Steeda springs. A stiffer FSB will tend to shift the balance back toward understeer with the stock springs. Besides, it's a reall PITA to install one.
Hatch Nation #90
TboneZX3 is offline
