Steeda Font & Rear Sway's - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2012, 03:45 PM   #1
GR34TWHI73N0RTH
GR34TWHI73N0RTH's Avatar
Fan#: 96598
What I Drive: 2012 Black SE Sport 5 Spd
Points 2,141, Level 27
Points: 2,141, Level: 27 Points: 2,141, Level: 27 Points: 2,141, Level: 27
Level Up 94% Completed
FF Reputation: 1 GR34TWHI73N0RTH Good Standing Member
Well here is some love and hate. I love the sway bars, they tighten up the handling and make the car really feel like i wanted it too. Its feel way more stable at high speeds, and around the corner's body role is cut down by more than half. I highly recommend these to anyone who really tears up the road's in the Focus.
The Rear one took maybe 20 min super simple no issue's at all. On the other had the front one was a pain in the ass. Ford put the oem one under the sub-frame so you have to drop it to even be able to reach it (wont even budge from the side, if you can get from out from there I'll consider you a god). So after you take apart the cross bars and drop the sub-frame its still has to be wedged out. Not easy! Then the major problem, the brackets for the front sway bar are identical to the rear ones but the bolts are not. I dont have the exact measurements of the bolts but the brackets fit the rear perfectly. The front bolts are extremely large, about a cm +, so you will have to machine down the brackets quite a bit to fit. The Brackets clearly weren't made to fits, their to small, the holes had to be made wider and longer, so hopefully i didnt weaken the integrity of them.
I waited a week to see what Steeda had to say, hoping that i might have accidentally been sent the wrong ones. Well sadly i have to say i was not. After a few emails and calls, the brackets are the only ones they have. I emailed them the photos on Monday and only received this in return "Thank you for the photos. I have passed them on to our manufacturing dept.". I called back today to get a some information, and was told it was normal, and up to the manufacture. He told me he would contact me if he heard, but no guarantee the problem would be solved. But i want to give them the benefit of the doubt, so ill update this if i hear otherwise. I would think Steeda would have ran into this problem if they had installed this before on the new focus, there is a pretty substantial and noticeable difference.
I'm not hating on Steeda, i love the parts and bars are quality. I have only heard good things about them, and that's why I'm surprised the brackets were over looked. Has any one else ran into this problem? I think i may have been the guinea pig with these. So if anyone had ran into this i would like to know?
I only have two photos, i probable should have taken a comparison one.
Before ( or standard rear)
After (a bad angle shot, the grinding down is hard to see, but i could fit my index finger through after we did)
Again, if you want sway bars for the MK3, buy these. There worth it, but be aware you will have to put in a little work to make the front brackets fit.
GR34TWHI73N0RTH is offline
Old 10-26-2012, 03:48 PM   #2
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,361, Level 42
Points: 4,361, Level: 42 Points: 4,361, Level: 42 Points: 4,361, Level: 42
Level Up 6% Completed
Forum Activity 6%
FF Reputation: 9 darkangelism Good Standing Member
Maybe I will do my RSB this weekend, it is still sitting in the box.
darkangelism is online now
Old 10-26-2012, 03:53 PM   #3
GR34TWHI73N0RTH
Fan#: 96598
Do it it takes like 20 min! super easy, brackets fit perfectly but take a sec to compare the front bolts to the brackets you were given, because their the same brackets for the front bar, and the bolts are way to big for them. But i love them anyways
Old 10-26-2012, 04:00 PM   #4
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 6%
I just have rear bar, so I dont have to worry about the front issue.
Old 10-26-2012, 04:07 PM   #5
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,383, Level 20
Points: 1,383, Level: 20 Points: 1,383, Level: 20 Points: 1,383, Level: 20
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 Borski Good Standing Member
How much did you end up paying for the RSB?
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 10-26-2012, 04:10 PM   #6
GR34TWHI73N0RTH
Fan#: 96598
Yeah but you can see what im talking about the brackets are identical.
Old 10-26-2012, 04:10 PM   #7
GR34TWHI73N0RTH
Fan#: 96598
330 for both, brandon hooked up the rest.
Old 10-26-2012, 04:22 PM   #8
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
The grinding you did looks good. I wouldn't worry a bit about the bracket's integrity.
I like the balance of the car so well with just the RSB that I don't believe I want to chance altering it with the FSB. Well, that and I don't want to commit to all that work with the front subframe either.
Hatch Nation #90
TboneZX3 is offline
Old 10-27-2012, 11:28 AM   #9
cobie56
Fan#: 84403
Can the rsw ONLY be done and not negatively affect handling cuz the front was left stock?
cobie56 is offline
Old 10-27-2012, 12:24 PM   #10
GR34TWHI73N0RTH
Fan#: 96598
If u add either I will improve the handling, ull feel a little bit of difference with the rear, but if u add the front ull feel the most improvement because it a FWD car, the ride is slightly rougher with both but doesn't bother me, i actualy like feeling the road more
