Old 10-26-2012, 01:38 PM   #1
Ford Foci
Fan#: 105324
What I Drive: Ford Focus 1.6 Petrol
FF Reputation: 1 Ford Foci Good Standing Member
Dials staying upright when engine turned off
Hello,
For the couple of weeks or so the petrol and engine temp dial have gone to the upright position when i have turned the engine off. When turning the engine off, the dials initially revert to the side but then after 1 or 2 seconds they revert to the upright position.
Initially i thought nothing of it, but having been away for the weekend i came back and tried start it (6 days after id previosuly started it) and the battery was dead.
My focus is a 1.6 zetec (uk version) 2002 and has done c.125,000. This is the first time i have had a problem with the battery having owned it for 2 years. I have previously had the power control module replaced (april this year) to correct an overheating problem.
Any ideas what this may be? Thanks in advance
Ford Foci is offline
Fan#: 1
Old 10-27-2012, 10:04 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
This part worries me.
I don't see any reason that the ECU/PCM should be replaced to fix an overheating situation.
It is true that the ECU controls the cooling fans, but not directly. The ECU actually sends a signal to a relay based on engine temp received from a coolant temp sensor.
I have never heard of a ECU not sending or receiving signals from good sensors.
So it just sounds fishy to me. But I haven't seen every possible scenario.
But the troubling part is how the ECU also controls the gauge cluster.
Signals the cluster display are first sent to the ECU from corresponding sensors/senders (coolant temp, crank position, vehicle speed, fuel level). In our US cars all these are sent down the same wires, but for your EU Focus they are sent down separate wires.
So we know the signals are all separate. Odds are 2 signal wires aren't going to fail at the same time. That leaves grounds and the question of do any share a ground. The answer is Yes.
I'm going off a wire diagram for a Mercury Cougar, which has the same wiring to the gauge cluster as your car. According to it, the fuel gauge and coolant temp gauge share a ground. This isn't at the connector behind the gauge cluster though; and I can't nail down exactly where the connector is. All I can find is the number of wires in it and that it may be green, should be 14 wires (or spots for wires).
I'm thinking this will be under the steering column somewhere.
I know it's in the vehicle cabin and not under the hood.
Find that connector and check the pins. Odds are one will be loose or disconnected.
If all's well then you have to follow the wires further.
There are no other connectors, which is what the electrical connector is called. But there are splices, 1 before and 1 after the connector. A splice is a group of wires soldered together.
You'll have to trace for these by hand and look again for loose wires.
If that doesn't solve the problem, the last part is the ground (or earth I believe you call them) at the battery.
There should be no other portion of a ground that would cause issue.
One thing to note is that a false ground might be able to feed backwards up the wire and cause a false reading to the ECU. So it could be the ECU was wrongly replaced, or replaced before a full diagnosis was done.
Best of luck and if you need any more help don't hesitate to ask.
iminhell is offline
