floor jack points - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2012, 01:37 PM   #1
lifespeed
Fan#: 102024
What I Drive: 2012 Ford Focus Titanium
FF Reputation: 1 lifespeed Good Standing Member
floor jack points
Where and how do I jack the front of my 2012 Focus? I just need to change the oil, but doubtless there will be other times I need to get under the car.
The pinch welds under the front door hinge floorpan look strong, but would likely get chewed up by the steel plate on the floor jack. What about the flat subframe that bolts on either side of the floor? Or is there some special protector I can put between the jack and pinch weld? What about placing jack stands once it is lifted. Also, pinch welds will only lift one side of the car, it is far more convenient to lift the entire front of the car.
I am somewhat surprised there doesn't appear to be a good place to support this car with a jack without scarring up the sheetmetal. Geez, what a headache!
Help!
lifespeed is offline
Old 10-26-2012, 01:42 PM   #2
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,361, Level 20
Points: 1,361, Level: 20 Points: 1,361, Level: 20 Points: 1,361, Level: 20
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 1 Borski Good Standing Member
I'm pretty sure there are little arrows on the unpainted plastic trim pointing to the jacking points.
Also check the manual for changing a flat, should be included in there.
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 10-26-2012, 01:45 PM   #3
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
It mentions it in the owner's manual, and I believe it may (I say may, since I haven't used the factory scissor jack, I use my floor jack) even have a small diagram on the sticker on the jack itself. But, at any rate, if you crouch down and look at the black plastic rocker cover, there is a little arrow (triangle really) embossed in the covers just aft of the front wheel for the front jack point and just ahead of the rear wheel for the rear jack point. You will also notice a "notch" in the metal seam just big enough for a hoist or floor jack to fit as well. If you use a large floor jack, and jack up the front high enough, you will see the back wheel (on the same side) also lift off the ground. Just goes to show how "stiff" and well built the unibody structure of these cars is. All my VW's did that as well.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 10-26-2012, 01:51 PM   #4
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
FF Reputation: 2 Brabs_Weather Good Standing Member
I has pictures on the jack...
White Platinum Tricoat Metallic
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 10-26-2012, 01:56 PM   #5
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
I use a block of wood on top of the floor jack. If it is a large floor jack I cut a piece of 2x4 to fit inside of the round dish like head. If it is a small jack, I just cut a piece of 2x4 to fit over the head. This will minimize the scuffing of the underside of the car. I really don't understand the design of the floor jack heads?
AZfocus2012 is offline
Old 10-26-2012, 02:10 PM   #6
pozi240
Fan#: 94835
Most floor jacks (good ones anyway) have rubber "inserts" for just that purpose. Work very well. If not, just use an old hockey puck.
pozi240 is offline
Old 10-26-2012, 04:48 PM   #7
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 86,025, Level 100
Points: 86,025, Level: 100 Points: 86,025, Level: 100 Points: 86,025, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Also for anyone that is interested, you can download free manuals here. (Page 312 will have the jack points information)
http://www.focusplanet.com/downloads...uidemanual.pdf
Tom is offline
Old 10-26-2012, 06:11 PM   #8
lifespeed
Fan#: 102024
Cars used to built with enough frame, or sub-frame, and thick steel to be supported by another steel plate undamaged. My 2009 Honda Civic could be safely floor-jacked under the radiator support without cushioning.
I'm not complaining (much), as the Focus is exceptionally rigid and appears to be a good design.
Old 10-26-2012, 06:13 PM   #9
lifespeed
Fan#: 102024
Thanks, I have the manual and the jack points appear to be the pinch welds. Still requires something other than a steel floor jack head to do it without chewing up a brand new car.
Old 10-27-2012, 01:40 AM   #10
cardoc1
Fan#: 90592
What I Drive: 2012 titanium 5door
Points 444, Level 8
Points: 444, Level: 8 Points: 444, Level: 8 Points: 444, Level: 8
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 cardoc1 Good Standing Member
Anyone consider using a set of ramps?
cardoc1 is offline
