Dry Sump worth it? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2012, 11:00 AM   #11
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,413, Level 61
Points: 8,413, Level: 61 Points: 8,413, Level: 61 Points: 8,413, Level: 61
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
So going with a stock pump with stock gears I should be fine?
It looks like Massive has a Ford Racing oil pump. Any different from the stock oil pump?
http://www.massivespeedsystem.com/fo.../i-252426.aspx
Or should I wait for C-F-M to get more of their gears in stock?
Edit:
Massive: Only sells the Ford Racing pump
TopSpeed: (appears to no longer be a sponsor of FF?) Does not have anything
C-F-M: Only has the stock pump in stock (still no ETA on their performance gears)
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 10-26-2012, 12:57 PM   #12
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,942, Level 100
Points: 51,942, Level: 100 Points: 51,942, Level: 100 Points: 51,942, Level: 100
Level Up 0% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
Buy-Sell-Trade Rating: (28)
The Ford Racing pump is the same as the stock pump , If your going to stay under 7400 then just go with the stock pump
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 10-26-2012, 01:23 PM   #13
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Am I right to assume that there is not much point in going over 7,400 RPM? IIRC for any power up their you need to do the custom intake and the independent throttle body changes. Even with that the top end (the Cams, valves, and porting) does not really push our power band up into those revs right?
Guess I can always pull the pump at a later date if I want to and install the gears I suppose.
Hatch Nation #42
Old 10-26-2012, 03:07 PM   #14
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
I have seen very few dynos that made power to even 6800 let alone 7400 , Unless you going for 400+ you wont need to go past 7-7200
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 10-26-2012, 03:41 PM   #15
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
1turbo, you are about the haughtiest I've met. You laugh at everyone else's ideas, the true mark of an--well I just won't say it. Nowhere does it seem to enter your brain that other ideas than your own might work, everybody else is wrong, wrong, wrong or just 'silly' and you can do no wrong at all, about as radical as one can get in social insecurity. It just gushes out of you. You seem to have a great need to be able to reinforce your own beliefs by stepping all over those of others while LOLing them all the while like it's funny. Yet you, or any other single man, do not know everything. From what you put out there I can see I've done some things that apparently would be impossible in your world of closemindedness.
I grew up through the implementation of dry sump on drag cars. Not the entire range of its' use of course but I got enough of it to know that anybody saying what I put out there was silly is showing.........well he's showing he's simply not as smart as he thinks he is. To you that'd be some burden, I guess LOLing it is after all best for you since you have no other way to resolve it in your head because you simply aren't able to. You certainly at times don't seem to be smart enough to use the greatest tool an engine builder has, the ability to be critical of your own output..........
If dry sump is so damn reliable then pray tell explain to those unlearned on the site why manufacturers don't put them on vehicles today. They could make more power and add mileage, both well proven facts. More problems and added cost is the reason why. Dry sump is almost always used on short life vehicles, not a mark of reliability. Even you cannot change that fact.
amc49 is offline
Old 10-26-2012, 04:06 PM   #16
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
I am planing on going to only about 350HP, and its going to be a daily driver.
As far as a manufacture installing one on production vehicles, there was a Mercedes that had one from the factory, and the only problem it had was that it used a oil cooler also and the average person was never able to get the temp up to the right temp.
not the most scientific site but a fairly well referenced site (operated by Discovery channel).
http://auto.howstuffworks.com/fuel-e...uestion331.htm
And of course a wiki site: http://en.wikipedia.org/wiki/Dry_sump
So on my tune just have the rev limiter set to 7,400 and go with the stock pump.
Is there aftermarket pick ups or oil pan combination that would decrease the likely hood of oil starvation to the pump during sustained hard lateral forces?
Or is the current design of the pick up, pan and oil capacity sufficient that the only way I will starve the oil pump (assuming proper oil levels) is when I roll the car?
Hatch Nation #42
Old 10-26-2012, 04:16 PM   #17
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Gentleman, keep this thread civil and on topic.
zetecDon is offline
Old 10-26-2012, 04:30 PM   #18
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
Correct set limiter to 7400 , I have taken my SVT to many tracks making over 320HP on the all stock engine with no issues ever , 152.2 MPH on the front stretch at VIR on GPS
Unless your doing a full blown race car where you can hook up hard where you can keep high speed through the corners dont worry about it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 10-27-2012, 02:16 AM   #19
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,069, Level 34
Points: 3,069, Level: 34 Points: 3,069, Level: 34 Points: 3,069, Level: 34
Level Up 13% Completed
Forum Activity 3%
FF Reputation: 9 emsvitil Good Standing Member
I'd go for a
windage tray/crank scraper
and a
accusump (or equivalent) for pressure drops.
Ed
emsvitil is online now
Old 10-27-2012, 11:27 AM   #20
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
the accusump sounds like a good idea, even good with a Turbo as it will provide some oil to the turbo after shut down. And for the NA you have instant pressure at start up.
not sure on the scraper... wouldn't the oil cloud provide lubricating of the block and cylinder walls?
the accumulator would also be an easy addition after the build is done and if I find that I do need it or want it, it would be an easy addition.
Hatch Nation #42
