Old 10-25-2012, 04:27 PM   #1
dckotwicki
Fan#: 50924
What I Drive: 2010 White SEL
FF Reputation: 1 dckotwicki Good Standing Member
Angry Hesitation at speed
I own a 2010 Focus SEL with 50K miles on it. I am noticing a slight / subtle hesitation while at speed. I can be doing 50MPH, 70MPH, cruise on or cruise off and I feel a hesitation from the engine. It is as if it is windy out and the car is buffetting slightly but is is not windy. It is also something that is more recent.
The engine idles perfectly.
( I am current with oil / oil filter and air filter changes)
If I bring the engine to 2500 or 3000 RPM it seems very smooth.
Since this began, I have also noticed an occasional roughness in the engine at start-up that smooths out right away.
When it began, I called the Ford dealer and asked if the car had a fuel filter that could be changed and was told "No". Is that correct?
Any ideas? ? ?
dckotwicki is offline
Fan#: 1
Old 10-25-2012, 04:53 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '07 ST and '86 XR4Ti
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (11)
I believe you have a "in tank" fuel filter on that model.
Only thing I would suggest is getting some new spark plugs (I would recommend Autolite 104's properly gapped).
You could also check and be sure there is no corrosion on your battery terminals.
'07 ST ; formally bewst'd
'86 XR4Ti ; 2.3L Turbo, 15psi
D23 Crew: #07
Jgrove998 is offline
Old 10-25-2012, 04:57 PM   #3
sgtsmasher
sgtsmasher's Avatar
Fan#: 65000
What I Drive: is a money pit
FF Reputation: 2 sgtsmasher Good Standing Member
how about when your coming to a stop?
does it do anything then, or when your slowing down?
any unusual vibrating?
the only reason i ask is cause ive had brake problems before and thats what it feels like, is that the car accelerates hard and brakes fast and when at speed the rotors can heat up some wicked and slow the car down to where you can notice a difference. i cant hurt to check. ive had brake new calipers fail on me before, its very common but can happen!
Hatch Nation #72
Call Me BRANDO or SGT BRANDO
sgtsmasher is offline
Old 10-25-2012, 05:00 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
50k miles over 2 years is average mileage. You shouldn't be having any problems with anything just yet- as far as spark plugs and coil boots go. I would consider pulling the coils and boots off each plug and seeing if there is any oil in any of the wells. You might have a bad valve cover gasket that is causing some problems.
Although earlier fuel filters were required to be changed every 20-30k miles, I do believe that Ford switched to a "lifetime" filter in your vehicle. Hopefully someone with an 2010 will chime in to verify.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-26-2012, 01:11 PM   #5
FordCustomerService
FordCustomerService's Avatar
Fan#: 79824
What I Drive: Ford Focus
FF Reputation: 18 FordCustomerService Great Standing Member
Originally Posted by dckotwicki View Post
I own a 2010 Focus SEL with 50K miles on it. I am noticing a slight / subtle hesitation while at speed. I can be doing 50MPH, 70MPH, cruise on or cruise off and I feel a hesitation from the engine. It is as if it is windy out and the car is buffetting slightly but is is not windy...
Hi dckotwicki,
I would advise that you make an appointment at your dealership so they can take a look. Ford certified techs are in the best position to diagnose and repair your Focus. If you have any questions, feel free to reach out to me via PM.
All great info, folks. Thanks!
Have a great weekend,
Crystal
FORD SERVICE
p: 800.392.FORD
f: facebook.com/FordFocus facebook.com/Ford
FordCustomerService is offline
Old 10-26-2012, 11:48 PM   #6
dckotwicki
Fan#: 50924
The vehicle behaves properly when braking and coming to a stop. I recently replaced the front rotors and pads. The car was acting like this before the new brakes and after the new brakes. There is no interference from the brakes... everything spins freely.
Anyone know what the spark plug gap is?
Old 10-27-2012, 06:21 AM   #7
coldbear
Fan#: 78292
What I Drive: 2001 Burgandy ZXT
FF Reputation: 1 coldbear Good Standing Member
Yep...get it in to a Ford Tech. They love working on FF's. They'll fix ya right up.
coldbear is offline
