Creaking/squeaking when going over bumps?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2012, 11:10 AM   #1
katkrazy2007
Fan#: 105248
What I Drive: 2008 Ebony Focus SES
FF Reputation: 1 katkrazy2007 Good Standing Member
Lightbulb Creaking/squeaking when going over bumps??
I'ven heard a lot of talk about this in the ford focuses. I drive an '08 SES and I have had the issue since I got my car. I appears to be the back end since I can push down on the back end and make it make the same sound as if its going over a bump in the road or over a lot of gravel. I was reading from some people that the problem most likely lies in the e-brake cable or in that little plastic piece that helps hold the cable? Does my decriptions sound that this could be my problem as well?
katkrazy2007 is offline
Old 10-25-2012, 11:50 AM   #2
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,479, Level 36
Points: 3,479, Level: 36 Points: 3,479, Level: 36 Points: 3,479, Level: 36
Level Up 86% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
Hey there,
I would advise that you make an appointment at your dealership so they can take a look. Ford certified techs are specially trained to track down mystery creaks/squeaks like the one you mentioned and get them resolved pronto.
Let me know if you have any questions. Have a great day!
Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 10-25-2012, 01:11 PM   #3
katkrazy2007
Fan#: 105248
Originally Posted by FordCustomerService View Post
Hey there,
Crystal
Thanks Crystal (:
How much would I be charged at a Ford dealer to have them look at something like that? My car isn't under warranty anymore and I bought it used. The squeak/creak isn't something serious with the mechanics (thank God), but it pretty much just drives me nuts -__- I'm sure whatever it is is small and I will probably laugh when its figured out!!
<Focus Freak>
Old 10-25-2012, 02:05 PM   #4
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 21%
Thanks Crystal (:
Hi again.
Ford dealerships are independently owned and operated, so there isn't a list of fixed prices for services. If you call your dealership, though, I'm sure that they'd be able to provide you with a quote.
Let me know if you need anything else.
Crystal
FORD SERVICE
p: 800.392.FORD
Old 10-25-2012, 02:44 PM   #5
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
I had a mystery creak like that in my 2000 Sentra. They tracked it down to a torn control arm bushing that had been damaged since new. It didn't start squeaking until it was a year old.
cbdallas is offline
Old 10-25-2012, 11:23 PM   #6
katkrazy2007
Fan#: 105248
That's crazy. The last thing you expect is to have something like that wrong with your NEW car. I actually have had the car thoroughly inspected by a mechanic and it now has new axles, new rack and pinion and when that didn't solve the "clunk" when I made turns or accelerated all at once (I know, this is irrelevant to the creak/squeak), they finally figured out that it was the control arm (: thanks God! I was reading about the creak possibly being something involving the e-brake cable and some type of plastic piece that tends to come loose causing this sound in many Focuses and all that would need is to be flipped and tightened, eliminating the squeak. Also, I know there are other bolts and what not that can come loose and cause creaking and squeaking involving the e-brake cable.
Is the sound my car was making (other than the popping and clunking) be because of the control arm as well? I haven't heard a current report on the status of my car today, so I don't know if changing the bad control could have helped? Any input??
<Focus Freak>
Old 10-26-2012, 06:24 AM   #7
rbrad6937
Fan#: 87784
What I Drive: 06 ZX4 SES, 2000 Excursion V10
Points 526, Level 10
Points: 526, Level: 10 Points: 526, Level: 10 Points: 526, Level: 10
Level Up 52% Completed
FF Reputation: 1 rbrad6937 Good Standing Member
It's most likely the E-Brake cable where it goes through a bracket in front of the passenger side rear wheel. I wrapped electrical tape where it was rubbing on the bracket, then secured it to the bracket with a strong tie-wrap. The squeak is gone for good. Hope this helps.
rbrad6937 is offline
Old 10-26-2012, 08:22 AM   #8
cbdallas
cbdallas's Avatar
Fan#: 100296
Unfortunately, there are SO many things on late-model cars that have the potential to cause strange noises, that it's nearly impossible to offer a solution without hearing the sound myself. I've had noisy halfshafts (Civic), brake caliper pins (Mazda3), strut bushings, (Sentra) struts, (Altima) control arm bushings, (Sentra) and ABS control unit (Frontier)....the list is long of the noises I've had resolved in the last 15 years. Definitely check out what rbrad is talking about...it's at least a great place to start.
cbdallas is offline
Old 10-26-2012, 06:45 PM   #9
katkrazy2007
Fan#: 105248
I will for sure. They've virtually taken the whole car apart and found nothing as far as the creaking is concerned so it'll be a huge relief if the problem is the e-brake cable! So is this thing with the e-brake cable something that can damage the car or is the just something that's gonna drive me nuts until taken care of (assuming that is actually the problem of course)?
<Focus Freak>
Old 10-26-2012, 08:32 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,394, Level 75
Points: 13,394, Level: 75 Points: 13,394, Level: 75 Points: 13,394, Level: 75
Level Up 36% Completed
Forum Activity 99%
Should be "Just" a drive you nuts issue... (grin)
Hadn't heard this one yet on as new a car as yours, but to "clear the air" on the issues found on older ones there were actually TWO areas that caused squeaks for different people.
1. the cable holders under the car for routing the E-brake cable.
This one had a TSB on it in my understanding (quoted by others on the forum) and additional padding in the rub area generally solved it in the cases I saw here.
2. An INTERIOR clip under the rear seat for the cable, which as you've noticed already some solved by "flipping" the clip so it worked better.
Lubricants, padding, alternative tie down methods, have all worked for different folks - LOTS of ingenuity from the members here once the location of the noise is found!
The interior one is the trick item, since no-one thinks it can squeak loud enough to be an issue at a glance, yet "fiddling" with it has been the cure for quite a few....
Good luck tracing your noise, they can be a PITA to track down!
sailor is offline
