Went from This Key fob to....that - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2012, 11:48 AM   #41
Incognito27
Incognito27's Avatar
Fan#: 34939
What I Drive: 2003 Ford Focus ZX5 Premium - White
FF Reputation: 3 Incognito27 Good Standing Member
Well for my year of car there weren't any. it was snaps . But i think newer ones are behind the Ford Sticker
Incognito27 is offline
Old 12-29-2012, 10:32 PM   #42
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,240, Level 35
Points: 3,240, Level: 35 Points: 3,240, Level: 35 Points: 3,240, Level: 35
Level Up 27% Completed
Forum Activity 8%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Does anyone know if this style will work i like it better..... it says it wont fit but Im thinking cause of the PATS chip which ill take from my old key and put in this new Fob but says its fits 2005-2009 focus.
qweesy is offline
Old 12-30-2012, 12:09 AM   #43
will.flickema
Fan#: 104204
What I Drive: 2002 Navy Blue ZTS
FF Reputation: 1 will.flickema Good Standing Member
It doesn't seem like it would. The original key fob has a square with the buttons and contacts located in the corners. This other fob has 3 on the front and one on the side. You could really only tell if it would work if you saw the inside of it. There's a possibility that the new fob had it's own chip that has to be programmed and all you need is the transponder.
will.flickema is offline
Old 12-30-2012, 01:36 AM   #44
2wheeladict
2wheeladict's Avatar
Fan#: 69029
What I Drive: 2005 focus zx4, 2003 cbr f4i
FF Reputation: 8 2wheeladict Good Standing Member
thats a vw/audi key. wont work. your ford chip will not fit in that like the other one will.
2005 ZX4: CAI, FRPP, eibach sportlines, hids
1983 kawasaki KZ550 cafe project
4 wheels move the body, 2 wheels move the SOUL
2wheeladict is offline
Old 12-30-2012, 08:40 PM   #45
Sevenev
Fan#: 106511
What I Drive: 2007 Pitch Black ZX3
FF Reputation: 1 Sevenev Good Standing Member
I have this exact style key. I had a ford dealership do all the dirty work but it worked fine for me.
Sevenev is offline
Old 12-30-2012, 09:01 PM   #46
Incognito27
Fan#: 34939
if you got a different circuit board inside then you can get the dealership to reprogram it to the car
Hatch Nation # 111
Old 01-01-2013, 08:36 PM   #47
iantm
iantm's Avatar
Fan#: 4167
What I Drive: 2007 Pitch Black ZX3 SE MTX
FF Reputation: 3 iantm Good Standing Member
I bought one of these. Had the local hardware store cut it to match one of my keys. Followed the programming instructions in the owner's manual with my two other keys. Works like a charm. Keep it on the keychain that I keep the key to the wife's VW on. Works great for me. Would highly recommend. Oh, my car's an 07 focus. Even with the remote removed from the assembly, the car will still start - so it has a PATS chip in in.
- Iantm
07 ZX3 SE MTX - enjoying every minute with it
Cannondale M700
MacBook Pro 15"
iantm is offline
Old 01-03-2013, 01:56 PM   #48
crazirich
Fan#: 107969
What I Drive: 2001 Wagon (Street Edition) yellow
FF Reputation: 1 crazirich Good Standing Member
There are a lot of Ford keys that can interchange with each other... The big difference is getting the right PATS chip. Older (00-05) Focus use a chip like a pill and was only shared with a couple cars like the Escapes (01-04) and Lincoln Ls (00-02). Other Ford vehicles use that style but a different coding to the pill
Older pats key with chip pulled out
Short of pulling the "pill" and taping it to your column or inside one of those larger body keys there isn't many options
If you have a newer focus (06-11) the chip is the same as every other car with that shape of key and even some with the square keys like an 06 Grand Marquis or a Town Car. The Integrated Fob keys out of cars like Fusion, Edge, 08up Escape etc. have the same key chip built in. This means you could program a Fusion style key to your car as well as some of the flip/blade keys you see. It seems like its a more poplar chip. Most fords use it from the 2000's on.
Newer "round" key
Fusion key
I broke apart one of the fob keys i got from the junk yard.
The integrated keys are like a fob and chip internal on the same board. The long skinny chip on the left is the PATS chip I believe. The chips in these will not work on the 05 and older cars but the Fob portion can still be programmed to your car and have one cut to match. I am probably going to stuff a pill from one of my keys into one and then program the fob to see if it will work.
* * * WARNING NOTE * * *
The integrated keys are NOT screwed together... they are GLUED and not intended to be taken apart other than the back cover coming off to service the battery. The 2012 keys are also LASER cut like a VW key and you wont find a hardware store cutting those things. Even some dealers don't have the machines to do it seeing they can cost up to like $8000
crazirich is offline
Old 01-03-2013, 03:37 PM   #49
crazirich
Fan#: 107969
IF you want a key fob that won't break get a billet aluminum one. No more broken busted keyring loop. Put it on a lanyard and swing it at someones head you'll get a nice goose egg!
UPR makes a couple
http://www.ebay.com/itm/99-09-MUSTAN...10610216894%26
http://search.uprproducts.com/?vwcat...e+case&x=0&y=0
Old 01-23-2013, 12:29 PM   #50
Theta SIgma
Theta SIgma's Avatar
Fan#: 87386
What I Drive: 2003 Twilight Blue ZX5
Points 754, Level 14
Points: 754, Level: 14 Points: 754, Level: 14 Points: 754, Level: 14
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 2 Theta SIgma Good Standing Member
I'm thinking of doing this too, what are the chances of me messing this up somehow? (I do have bad luck sometimes)
Also, what is the quality of the fob?
- ΘΣ
The 5
Toms Tune, SVT Headers, MH Motorsports CAI, 2.5" SS Borja, SVT Suspension, MTX-75 transmission swap
Theta SIgma is offline
