Horn wiring help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2012, 01:23 PM   #1
WEMKAY
Fan#: 101187
What I Drive: 98 nissan sentra (dead), '04 ZX3
Points 290, Level 5
Points: 290, Level: 5 Points: 290, Level: 5 Points: 290, Level: 5
Level Up 80% Completed
FF Reputation: 1 WEMKAY Good Standing Member
Horn wiring help
Sorry in advance if this is the wrong forum. I didn't see anything on this in the "how to" section
The horn in my zx3 does a few weeks back. I spent the money on some supertones because I drive a lot for work.
My question is on wiring. Hooking up the two horns correctly to the relay is easy enough. How the focus horn is grounded is another.
I'll include the pictures of the instructions later, maybe someone can make sense of it.
WEMKAY is offline
Old 10-24-2012, 02:13 PM   #2
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
FF Reputation: 20 xxMichaelAnthony Great Standing Member
I connected mine to the battery and used the stock wires to signal the relay that came with them.
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Old 10-25-2012, 07:51 AM   #3
WEMKAY
Fan#: 101187
Points 290, Level 5
WEMKAY is offline
Old 10-25-2012, 07:52 AM   #4
WEMKAY
Fan#: 101187
Points 290, Level 5
So like the top picture
WEMKAY is offline
Old 10-25-2012, 11:33 PM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
The top pic is similar to how the Focus is wired.
The horn relay is supplied with a constant voltage from the Battery Junction Box (BJB) - fuse 32 20A - and the horn receives voltage from the switched side of the relay. The relay switch is controlled on its ground side by the steering wheel switch.
BC_ZX3 is offline
Old 10-26-2012, 07:21 AM   #6
WEMKAY
Fan#: 101187
Points 290, Level 5
Awesome. I'll be putting it in this weekend.
WEMKAY is offline
Old 10-27-2012, 06:03 PM   #7
WEMKAY
Fan#: 101187
Points 290, Level 5
Ok, that made sense at the time. Now I'm lost. However they are mounted. One where the old one was,the other in the space under the driver side headlights.
WEMKAY is offline
Old 10-28-2012, 06:27 PM   #8
WEMKAY
Fan#: 101187
Points 290, Level 5
WEMKAY is offline
Old 10-28-2012, 06:29 PM   #9
WEMKAY
Fan#: 101187
Points 290, Level 5
One under the headlight, the other in the old spot. I might move the lower one over to the other side sometime but it doesn't seem to have the same easy spot to mount.
WEMKAY is offline
Old 10-28-2012, 07:13 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,449, Level 75
Points: 13,449, Level: 75 Points: 13,449, Level: 75 Points: 13,449, Level: 75
Level Up 50% Completed
Forum Activity 99%
Looks like you got 'em wired, working OK?
With BC's description to go by, the Focus runs the stock one on a relay already - So I'd just hook the new ones to the existing wiring instead of putting ANOTHER relay in the circuit.
Luck!
sailor is offline
