Installing rear drum - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2012, 12:05 PM   #1
bdahlka
Fan#: 97311
What I Drive: 2003, Black, Focus
FF Reputation: 1 bdahlka Good Standing Member
I am changing the rear brakes on a 2003 focus and Cant seem to get the drum back on.. I compressed the cylinder and have the clips in place.. I tried pounding it on and caused slight damage to the outside of the pads so i am fearful of continuing to force it on.... any suggestions?
Thanks in advance
bdahlka is offline
Old 10-24-2012, 03:19 PM   #2
jeffkyle
jeffkyle's Avatar
Fan#: 89863
What I Drive: 03 SVT, 02 ZX3, 01 SE
Points 396, Level 7
Points: 396, Level: 7 Points: 396, Level: 7 Points: 396, Level: 7
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 jeffkyle Good Standing Member
You have to adjust the bar or "adjuster" to the smallest distance, Then put the drum on and pull the parking brake a few times to set the shoes out to the drum. Make sure to torque the spindle nut properly so you dont waste the bearing.
jeffkyle is offline
Old 10-24-2012, 03:23 PM   #3
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
I had the same problem. I ended up camfering the edges of the pads to get them started. Then I tapped the drum on opposite sides to get them on.
TerryB is offline
Old 10-24-2012, 07:15 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Yes that's correct, however the next time you take your drum off, try removing the 4 bolts holding the hub instead of the big nut that holds the drum to the hub. It's much easier, and about all you need is some blue thread lock.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-25-2012, 10:38 AM   #5
bdahlka
Fan#: 97311
How is this accomplished? Is this why i cant seem to get the drum on?
bdahlka is offline
Old 10-26-2012, 01:06 AM   #6
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
He just said so, if you are going to question it you won't get much more help...............
Nothing personal but if you can't figure it out you don't belong working on brakes.
You swing the 1/4 circle shaped quadrant on the bar with the little spring on it one way or the other to make shoe setup wider or narrower. Can't make it any clearer than that.......
After that one or two times pushing down on brake pedal will adjust it if you put it together right.
amc49 is offline
Old 10-26-2012, 03:27 AM   #7
bumble21
Fan#: 95826
What I Drive: 2001, Black&Yellow, ZX3
FF Reputation: 1 bumble21 Good Standing Member
I honestly don't understand the animosity. Forums are here for people to learn and share from what I know everyone on this forum used to know nothing about cars cut him a break. Bdah I found it easiest to adjust this by taking a thin flat head screwdriver and lightly tapping it to get it to close, sometimes if its old it'll get jammed a little and take some finesse to get the teeth moving. Also just as whynot said make sure to torque the nut correctly. I believe the procedure is 10 turns counterclockwise while torquing the nut down to get it to seat the nut on the bearing properly. If you don't you'll be replacing the drum in like 6 months from the deafening humming you'll get (been there its quite obnoxious lol) good luck
bumble21 is offline
Old 10-26-2012, 03:31 AM   #8
bumble21
Fan#: 95826
As for why the drum won't go on the adjuster in the drum style brake acts similarly to the piston in caliper brakes. It keeps the shoes/pads close to the contact surface so when you depress the pedal the pads do not have to travel far to creat contact. Just like how you must depress the piston in calipers to get them back over the pads and rotors you must bring the adjuster back to close to put a drum back on. This is why "pumping" the brake system after service is necessary to push the pads back to where they almost touch the metal
bumble21 is offline
Old 10-26-2012, 04:49 PM   #9
amc49
Fan#: 96610
Forum Activity 54%
Trying to be patient..........
Don't know where you got the '10 turns' thing from but it is totally and absolutely worthless. The torque is around 200 ft.lbs. on the nut, anything else and bearing is scrap.
Your last post says absolutely nothing. There is NO ADJUSTING THESE when brake goes back together, you make them way too loose so drum goes on easy and first time brake is worked they adjust automatically if you put it back together right.
Reason for animosity is that you are working on brakes, anything else is moot. Brakes can KILL YOU and SOMEBODY ELSE too, if you are not 100% clear on what to do you should not be touching them.
Forgive me for being a jerk.
amc49 is offline
Old 10-26-2012, 05:15 PM   #10
xxMichaelAnthony
xxMichaelAnthony's Avatar
Fan#: 58459
What I Drive: 2001 CD Silver ZX3
Points 15,567, Level 80
Points: 15,567, Level: 80 Points: 15,567, Level: 80 Points: 15,567, Level: 80
Level Up 44% Completed
FF Reputation: 20 xxMichaelAnthony Great Standing Member
It would be nice if people actually knew our rear brake set up before they started spouting a bunch of useless info about a different drum setup.
Adjust the cam on the bar to the shortest position. The drum will go right back on. Firmly push the pedal once after its all back together and its adjusted where it need to be.
The hub is a sealed bearing. No need to turn the drum while tightening the hub nut to seat the bearing like you have to do with tapered bearings. The hub nut is torqued to 173ft/lbs IIRC
http://effyeahfordcars.tumblr.com
[HOONIGAN]
iTroll
xxMichaelAnthony is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
