improving SEL handling - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-23-2012, 09:13 PM   #11
Phokus
Shiny Metal Titanium
Phokus's Avatar
Fan#: 60433
What I Drive: 2013 Performance Blue Titanium Seda
Points 12,582, Level 73
Points: 12,582, Level: 73 Points: 12,582, Level: 73 Points: 12,582, Level: 73
Level Up 33% Completed
FF Reputation: 7 Phokus Good Standing Member
Buy-Sell-Trade Rating: (9)
But the rear mazdaspeed3 bar fits right?
1965 Mustang Coupe 289 4spd
2003 Land Rover Discovery II SE
2013 Lincoln MKZ Hybrid
Phokus is offline
Old 10-23-2012, 09:46 PM   #12
jsr72
Fan#: 97393
What I Drive: 2012 Focus SE
Points 151, Level 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Level Up 2% Completed
FF Reputation: 5 jsr72 Good Standing Member
Originally Posted by cobie56 View Post
Can u explain? I always thought sway bars only affected lateral forces. I guess i thought tires,wheels, shocks/struts and springs would affect ride quality
Bars do effect handling balance. That is their primary purpose, but they also affect ride quality on anything but the smoothest surface.
When both wheels move together, the bar adds little (theoretically nothing) to both wheel rates, i.e. smooth roads. But if one wheel moves relative to the other, such as a single wheel hitting a bump or pothole, the bar resists that torque and increases the single wheel rate.
jsr72 is offline
Old 10-24-2012, 08:40 AM   #13
cobie56
Fan#: 84403
Guess i never thought of it that way.. but ur right. I don't mind, however, a slightly firmer ride so long as it's not harsh or overly hard. Now onto shocks n struts......
cobie56 is offline
Old 10-24-2012, 09:35 AM   #14
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: Slammed S-10
Points 8,062, Level 60
Points: 8,062, Level: 60 Points: 8,062, Level: 60 Points: 8,062, Level: 60
Level Up 56% Completed
FF Reputation: 7 Chaos09 Good Standing Member
Just buy some coilovers! One of the best mods I've done to my car.
Sonic's MK3 Crew #9 Chaos!
Chaos09 is offline
Old 10-24-2012, 10:21 AM   #15
cobie56
Fan#: 84403
that was my first inclination is to replace struts/shocks, then, second, wider and/or lower aspect ratio tires.
I think these are the two easiest to do and will yield the most results for the least effort. agree?
Any opinions on brands? someone suggested just going w/ the ST struts/shocks as the easiest and least expensive way to go.
cobie56 is offline
Old 10-24-2012, 10:38 AM   #16
jsr72
Fan#: 97393
Points 151, Level 3
Nearly every suspension part on the ST is different. The front struts will swap in as some have mentioned/done. However the rears shocks are mounted high on a different spindle and are much shorter than the standard Focus.
Why not just upgrade to the Ti Handling front springs and front/rear dampers? Throw on the summer tires/wheels and voila, a Ti Handling Pkg.
jsr72 is offline
Old 10-24-2012, 11:00 AM   #17
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
I would recommend doing all 4 springs.
Joined the dark side.
Zillon is offline
Old 10-24-2012, 11:06 AM   #18
cobie56
Fan#: 84403
Thnx for the info on the rears... noted.
as for summer tires. i want to avoid that as i don't want to be changing out tires twice a year. I did that w/ my last care it was a pita. I'll stick w/ so-called hi performance all seasons and so will stay w/ the 17 inch wheels, too.
cobie56 is offline
Old 10-24-2012, 12:32 PM   #19
cobie56
Fan#: 84403
First, I want to thank all who have added their input here. It's been helpful.
After doing some research into coil overs (as one contributor suggested) I'm not certain i wanna go that route. A bit pricey for sure and prob. more than i need to just 'firm up' and 'tighten' and reduce sway a bit. I found this site (http://www.pirate4x4.com/tech/billav...lovers/Part_1/) which was very informative but , frankly, I am more at sea than before.
I prob. just wanna go with 'performance' shocks/struts to take things up a notch and with that in mind, did some on line searching but came up with not much and even more confused as to what to purchase. I already have the 17" contis that come w/ the car and i don't find them very performance oriented so am not opposed to swapping them out for maybe 225/45/17 tires to improve things a bit. I would think that w/ the bigger tires and better shock/struts handling will improve sufficiently. Opinions?
As i said, i just wanna take things up a notch, perhaps not to Ti levels but def in that direction (altho Ti level handling is just fine, too). If i were to rely mostly or fully on just shock/strut replacement do any of you have specific recommendations (and why)?
thanks
cobie56 is offline
Old 10-24-2012, 01:03 PM   #20
jsr72
Fan#: 97393
Points 151, Level 3
You're going to be a little bit on the narrow side for rim width with that particular tire if you keep your stock wheels.
jsr72 is offline
