Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 10-23-2012, 01:20 PM   #1
cobie56
Fan#: 84403
What I Drive: '01 ZX3, '07 Civic '12 SEL
improving SEL handling
I posted this in the Wheel/tire/suspension section but didn't get a full response so i thought i'd post it here.
After driving a Titanium the other day (w/ 18" wheels n handling pkg) i realised how 'sloppy' my SEL handles by comparison
Other than changing spring rates and sway bars , IYO, can i gain some better handling characteristics by going w/ a more performance oriented shock/strut set up and wider and/or stiffer walled tire and/or lower aspect ratio tires?
Any recommendations n opinions would be welcome.
cobie56 is offline
Fan#: 1
Old 10-23-2012, 02:06 PM   #2
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
Do you have 16" or 17" wheels now? If you 16's that is a big part of it. I would go with a F/R sway bar set first, as it is an easier install and cheaper than the strut/spring change over, and you get to keep some of the softer ride for the daily commute. Or start with the tire/wheel setup if you had 16's. You will definitely want to have the 17" 50's at a minimum. You can do 18's but they will probably rub as the Ti has a different rack to prevent this, yielding a larger turn radius, at least that is what I have heard. Plus with 18" 45's you will give up a lot of the ride comfort. But maybe you don't care about that. I am old and like my comfort.
AZfocus2012 is offline
Old 10-23-2012, 02:10 PM   #3
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 01 F150. For now.
FF Reputation: 2 Kevastator Good Standing Member
Whoops, AZ posted before I finished writing lol ^^
Larger wheels can make a car handle better: the less sidewall on your tire there is to flex, the better it will handle. So upgrading to larger wheels and better tires is one route.
Also, check out Steeda. They sell upgraded swaybars, and they can give you a significantly better handling car, and they won't cost nearly as much as switching to performance coilovers,
[Rally Revolution]
Rocky Mountain Fanatic
[HOONIGAN]
Originally Posted by svt1391 View Post
Who's got 3 thumbs and is excited? This guy!
Kevastator is offline
Old 10-23-2012, 03:08 PM   #4
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 GTI
FF Reputation: 26 Zillon Great Standing Member
Front sway is not an easy install by any means. You have to drop the front subframe to do it.
This is what I've done to my car thus far to improve handling:
Focus ST front struts
Focus ST front strut mounts
Koni Sport rear dampers
Eibach Pro kit springs (.8" drop) (I'd recommend the Steeda springs over the Eibachs)
Steeda 25mm rear sway bar
18x8 Axis XMX wheels w/235/40R18 tires
Night and day difference. Led my buddy around in his new FR-S on Sunday, and he was rather impressed with my Focus' abilities.
Joined the dark side.
Zillon is offline
Old 10-23-2012, 03:35 PM   #5
slowmazda3
Fan#: 58220
What I Drive: a rental
FF Reputation: 0 slowmazda3 Newbie
With all of that being said, the stock suspension can generate more lateral grip than the tire will allow. Take the stock 16s, throw some 225 50 16 hoosier a6 and it will grip more than a 991 Carrera.
Ultimately, if you're looking for less perceived body roll without compromising ride quality:
Eibach Springs
Quality Dampers (ST ford parts are cheap and will do the job), have to go bilstein or koni in the rear
IF you are looking for all out handling performance with a tendancy to oversteer:
In addition to the above
MS3 Hotchkis rear bar (32mm hollow)
17 inch wheels
245 40 17 Hankook Ventus R-S3 (will rub without rear fender roll)
I bought a mazda and all I got was some crappy motor mounts and wheelspin.
slowmazda3 is offline
Old 10-23-2012, 03:55 PM   #6
Zillon
Zillon's Avatar
Fan#: 17393
Jeff, the Hotchkis bar bolted right up without any issues?
After Sunday's backroad run, I've decided that the 25mm Steeda bar isn't quite enough for my personal tastes, and I've been thinking about trying out one of the thicker MS3 RSBs.
Zillon is offline
Old 10-23-2012, 06:50 PM   #7
cobie56
Fan#: 84403
Wow. I cant believe i left out that important piece of info. Duh!!! Yes i do have the 17 inch wheels
cobie56 is offline
Old 10-23-2012, 06:59 PM   #8
cobie56
Fan#: 84403
Iyo, is installing beefier sway bars negatively afecting handling vis a vis oversteer/understeer?
I really dont wanna replace springs or lower the car if i can help it. Someone else mentioned ride quality and that is a concern as here in the northeast our roads get pretty crappy from winter frost (and i drive in quebec alot where they are even worse). So id like to keep the 17 inch wheels. Currently the 17 in tires are 50 series and i could go to 45 series if needed but no lower.
Thanks to all who have responded. Id be interested in any personal experiences as a result of any suspension work.
cobie56 is offline
Old 10-23-2012, 07:26 PM   #9
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: 2012 Focus SE
FF Reputation: 3 jsr72 Good Standing Member
Beefier bars will negatively impact rough road ride quality.
jsr72 is offline
Old 10-23-2012, 07:41 PM   #10
cobie56
Fan#: 84403
Can u explain? I always thought sway bars only affected lateral forces. I guess i thought tires,wheels, shocks/struts and springs would affect ride quality
cobie56 is offline
