Headlamp bulbs blowing regularly - Focus Fanatics
Old 10-22-2012, 01:47 AM   #1
suechad
Fan#: 105142
What I Drive: 2002 blue ford focus ghia
FF Reputation: 1 suechad Good Standing Member
My main bulbs keep blowing - last time I replaced them they lasted 3 weeks! Is this just unlucky or could there be an electrical issue?
suechad is offline
Old 10-26-2012, 08:02 AM   #2
jburkey28
Fan#: 105295
What I Drive: 2009 Cobalt SS/TC
FF Reputation: 1 jburkey28 Good Standing Member
Sounds like an electrical issue.. I had this problem on a truck of mine, the bulbs were getting too much juice.
jburkey28 is offline
Old 10-26-2012, 08:02 AM   #3
jburkey28
Fan#: 105295
Check the wiring connections to make sure they're in good shape. Could also be getting too little juice I suppose..
Old 10-26-2012, 10:40 AM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
I ran two Focuses a 2004 Zetec wagon 183,000 miles and a 2000 SPI sedan for ~ 50,000 miles.
Not one headlight was ever replaced
You have an electrical issue
Get yourself a multimeter
Go to YouTube
Type in battery, alternator, multimeter
There you will find a multitude of 'How to' videos of varying quality
Now having said this I suppose if you drove at night alot and went over pot holes, speed bumps and the like that MIGHT make a difference. I would imagine your front end would have disintegrated by now.
How does the connector going on the head light look, if it is all burned up [bad connection] then the heat generated by a bad connection could make a head light fail earlier
mikeeshaq is offline
Old 10-27-2012, 07:58 AM   #5
Monoblanco
Fan#: 59784
What I Drive: 2002 bright yellow ZX5
FF Reputation: 3 Monoblanco Good Standing Member
Sounds as if the voltage regulator in your alternator could be bad, causing high output voltage. This could cause damage to way more than just light bulbs, battery and ECU just to name a couple. Good idea to deal with this right away.
Good luck,
Monoblanco
Monoblanco is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
