Clutch acting a little strange - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-20-2012, 05:00 PM   #1
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
Well Ive been driving my 06 2.0 with the 5 speed for about 20000 miles and Ive gotten used to the clutch not needing to be driven literally all the way down to the floor to disengage power from the engine to the trans, in the past week and a half the clutch needed to be pressed to the floor before it would disengage and allow me to shift. Im relatively new to working on clutches as the cars Ive worked on in the past were autos. The car has about 113500 miles on it so is there a chance my clutch is about to burn out or is this a sensor issue. The only research Ive done is doing a trans fluid change, though that was actually partiAlly a PM thing I didnt notice any metal shavings in trans fluid or any odd discoloration. Other than the slightly annoying clutch issue she runs great. Just a note my maintenance is always kept up to snuff and I dont peel out the car often, only a little and on the occasions when Im on a steep hill and Im stopped.
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 10-21-2012, 07:58 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Check your fluid level, Brake and clutch share the same reservoir IIRC. Also do a search for clutch slip test on the site, to test your clutch. Good luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 10-22-2012, 10:28 AM   #3
grayzx35speed
Fan#: 94839
Fluid levels good, Ill check to see if the clutch is slipping after work. Thanks for.the tips.
