Axel boot torn....new boot or half shaft?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-20-2012, 03:38 PM   #1
Blown2go
Fan#: 90976
What I Drive: 04 Lightning
FF Reputation: 1 Blown2go Good Standing Member
Hello all! So the the other day I replaced all four shocks on the ol' focus SVT as she has hit 90k. I didn't realize it until a day later that somehow the inner CV joint axle boot has ripped and has sprayed grease all over. Oreilly auto sells new remanufactured half shafts for 70 dollars or a new boot kit for 20. Is it worth replacing the entire axle while I have it all apart? Or should I just take the shaft out and install a new boot?
Thanks!
Blown2go is offline
Old 10-21-2012, 07:34 PM   #2
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 4,095, Level 40
Points: 4,095, Level: 40 Points: 4,095, Level: 40 Points: 4,095, Level: 40
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 2%
FF Reputation: 11 SVTF4243 Great Standing Member
Replace the shaft worth the extra $50
Changing the boot is A PITA
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
Old 10-21-2012, 10:10 PM   #3
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
$70 isnt terrible. Id go that route, or order an empi axle off of ebay for the same price.
BigRed03 is offline
Old 10-22-2012, 09:19 PM   #4
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
isn't the svt axel shaft bigger than a standard focus?
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 10-22-2012, 11:49 PM   #5
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
i cannot recall, but i think it has a different number of splines on the differential side.
BigRed03 is offline
Old 10-23-2012, 12:45 PM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,007, Level 74
Points: 13,007, Level: 74 Points: 13,007, Level: 74 Points: 13,007, Level: 74
Level Up 40% Completed
Forum Activity 99%
I 2nd that ^^^^ Replace the axle. Your going to have to pull it out anyhow & I'd rather be pulling in a new one. And how long has that joint been that way, w/ the boot tore? Who knows.
felixthecat is offline
Old 10-23-2012, 11:02 PM   #7
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
I have a tendency to go for the boot alone. Or I did, back when one could find the correct boot easily. Not that hard to change one. Problem nowadays is that most boot sizes have dried up over the counter, they would much rather make the sale of the bigger part. Some of the O'Reilly boots I've seen were abysmal in quality or wrong size (doesn't matter that they say it will work, they'll say anything) and the split ones are absolutely worthless. Meaning............in this case the $50 extra is a really good deal.
amc49 is offline
Old 10-30-2012, 02:52 PM   #8
Blown2go
Fan#: 90976
well....I replaced the boot on the passenger side. The half shaft just pulls right out at the cups so no need to pull the axle. The only problem was that the ford half shaft for the inner cups is not perfectly round meaning the new universal boot wouldn't seal. The solution i came up with was to cut and use the old end of the boot and clamp the new boot over the very end of the old boot. Works great....but for the driver side i will be replacing the entire axle. Pain in the rear either way! Looks like the driver side half shaft will be easier to change however!
Blown2go is offline
Old 10-31-2012, 08:44 AM   #9
amc49
Fan#: 96610
Forum Activity 11%
Driver side is harder to get out of trans.......................
amc49 is offline
Old 10-31-2012, 10:38 AM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
To me drivers is easy to get out , remove Pass side CV from trans , have everything loose on drivers side and put psi on the CV (pry with large screwdriver)on the trans , go in through the trans on the pass side with a long punch give the dirvers side a good hard rap and it will fall right out , works every time for me
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
