05' focus ZX 3 fog lights install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2012, 10:31 PM   #1
ursnkb8
Fan#: 97759
What I Drive: 2005 Pitch Black ZX3
FF Reputation: 1 ursnkb8 Good Standing Member
Anyone know how to install fog lights on a ZX 3 05' focus? I know I have to get the fog lamp bezels for it. Do I have to take the bumper off to install the bezels? Or could I just pop the old ones out and the new ones in without taking the bumper off?
I was just gonna wire the fog lights to the headlamps wires but if there's a easier way to wire them, let me know!
ursnkb8 is offline
Old 10-20-2012, 08:41 AM   #2
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 1 markwb Good Standing Member
Remember, the fog lights should be interlocked (via relay) to turn off when the high beams are turned on. As far as the actual mechanics of installation of fog lights, I have no idea, but would be interested in knowing as well.
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 10-20-2012, 12:00 PM   #3
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
The pics are from an 00 - 04, but the wiring guide below will work for all years:
http://www.focusfanatics.com/forum/showthread.php?t=229873
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 10-20-2012, 12:47 PM   #4
ursnkb8
Fan#: 97759
it looks easy to wire them up correctly. I would just have to get a new switch to turn my lights on. My focus is just the base model so I doubt it has the wires in already.
ursnkb8 is offline
Old 10-20-2012, 03:22 PM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
You can install without taking the bumper off. You need the bezel and (of course) the lamp assembly. The lamp assembly mounts with 2 '10mm' screws at the 'top' and 1 '10mm' at the bottom (NOTE: maybe there 7mm. I forget). Electronics>> If you don't have the factory switch, you can mimic the normal operation by using a automotive type relay with a N/C (normally closed) term. Run power to the fogs through the N/C relay switch terminals. Wire the coil to ground, and the power lead to the high beams. When the high beams come on, they power the relay and the fogs will turn OFF. This is a good method as the relay is usually off as I will assume most folks don't drive with there high beams on constantly. Don't forget to put an inline fuse (10A) to the fogs, before the relay.
ADD >> Relay info. If the relay does not specifically state it is normally closed (N/C or NC). Then assume it is N/O. You can use 14 gauge wire. The relay should be mininum 10 amps (same as the fuse).
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 10-21-2012, 12:48 AM   #6
ursnkb8
Fan#: 97759
ok thanks! I asked because i know someone who has a mazda 6 and they have to take the bumper off to install them. I was hoping i didn't have to but i dont. Thanks!
ursnkb8 is offline
