Is my engine "seized" - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2012, 08:21 PM   #1
biederboat
Fan#: 9840
What I Drive: 2000 ZTS
Points 878, Level 15
Points: 878, Level: 15 Points: 878, Level: 15 Points: 878, Level: 15
Level Up 78% Completed
FF Reputation: 1 biederboat Good Standing Member
I started a "starter" thread (as in engine starter) as I thought that's what the issue was but now I'm sure it's not. If you want to visit that thread, here it is but I really don't think there's any valuable info there: http://www.focusfanatics.com/forum/showthread.php?t=299926
So basically I have a situation where a previous and a new starter (along with a tested battery and new cables) are not turning the engine over fast enough (sounds slow). So I took out the spark plugs, disconnected the drive belt and put a breaker bar/socket over the front crank pulley. It's feels "restrained". No obvious grinding noise but I would think with the plugs out, drive belt off and 230K miles the engine would turn easily by hand but it really doesn't. It has easier and harder spots but at no point can you turn it easily with one hand on the pulley. Also, with the breaker bar on it, it doesn't feel smooth (feels ok when turning by hand though). The plugs and oil look fine.
I tried all the driven accessories (pumps, alternator, etc.) and they all spin just fine.
Any thoughts?
Thanks,
BB
biederboat is offline
Old 10-19-2012, 08:55 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
if you can spin it its not completely seized... there could still be something wrong with it though.
I think you need to check the voltage drop on your battery cables.
mikebontoft is offline
Old 10-19-2012, 09:45 PM   #3
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, 03 ZX3
Points 3,015, Level 33
Points: 3,015, Level: 33 Points: 3,015, Level: 33 Points: 3,015, Level: 33
Level Up 77% Completed
Forum Activity 4%
FF Reputation: 9 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
Sounds like a spun bearing.
Drain the oil and look for metallic bits.
02ztsian is offline
Old 10-20-2012, 03:36 AM   #4
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
I disagree, probably nothing wrong with it.
Unless there is a positive reason (ran out of oil, abuse of engine, etc.)........if motor last ran all right then not motor.
amc49 is offline
Old 10-21-2012, 05:41 PM   #5
biederboat
Fan#: 9840
Hey guys, sorry for the late response, I forgot to "subscribe" and assumed no one had responded, shame on me.
So here's where I'm at (or rather the car's at): Bad timing belt (that's at least part of the trouble). Earlier, I'm sure I pulled the top cover back to make sure it was turning but, in any case, it's not now. Had a lot of miles and I was hesitating whether or not to drop the $600-700 or just get rid of the sucker. Not really any worries here, I totally got my use out of this car.
The only thing I'm wondering is if it might be ecomonically repairable. As it's a DOHC, I understand these are "clearance" designs. Also, near as I can tell, the failure happened either while turning off or attemping to restart. I've heard of other cases similar to this where they lucked out. Any comments? I'll do some searching as well.
Taking delivery of a long overdue 2013 SE Hatchback, perf blue, stick, leather, moonroof, yee haa!!!
Thanks,
BB
Old 10-21-2012, 05:48 PM   #6
biederboat
Fan#: 9840
Update: Here's what my search came up with: http://www.focusfanatics.com/forum/s...en+timing+belt
Is everything here still current? After writing my previous post, I am wondering if the belt broke maybe because the engine has seized. Any thoughts? What would turning an engine that had otherwise good compression but a broken belt be like? Some valves open, some closed, would it be alternately hard to crank and then easy to crank? That's what it sort of feels like when cranking by hand. Even when turning with the starter it would seems to spin at normal speeds for brief instances.
BB
Old 10-21-2012, 06:22 PM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
If you still have the spark plugs installed, then the engine will have hard and easy places when cranking by hand whether the timing belt is intact or not. If you can turn it at all by hand, then it's ok. If you had bearing damage, it would not turn by hand easily. You'd have to put hundreds of pounds of pressure on a breaker bar to get it to move- if at all.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-21-2012, 06:25 PM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
Yes, the Zetec is a non-interference engine, no valve damage unless the cams were changed out. Now with over 200k miles.... there could simply old engine damage from use.
Be eclectic.
Old 10-21-2012, 09:28 PM   #9
biederboat
Fan#: 9840
Thanks guys. As I forgot to subscribe (thinking no one had responded) I posted my dilemma on another forum I use and a guy chimed in to say "just throw a cheap timing belt on it" and see what happens. That sounds like a good approach. I haven't done one of these but I've done just about everything else with this car and many others so not afraid to tackle another repair when there's only the possibility of salvaging something that was considered to be "Pick N Pull" raw material.
BB
Old 10-21-2012, 09:44 PM   #10
amc49
Fan#: 96610
Forum Activity 3%
Make sure the two timing belt idlers are not seized up.
amc49 is offline
