COBB Initial Focus ST R&D Findings - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 10-19-2012, 06:41 PM   #1
COBB Tuning
Fan#: 105020
What I Drive: 2013 Focus ST
FF Reputation: 1 COBB Tuning Good Standing Member
Iíve introduced myself on this forum before, but for anyone that missed it, my name is Braden and I am an R&D Calibration Specialist at COBB. I am working on the Focus ST, mostly because I begged Trey to let me.
I bought my own ST as my daily driver just a few weeks ago. Itís a great car and should prove to be a good tuner ride in the future. I come from owning just about every turbo Subaru there was, with my last one being a 2004 WRX wagon that was making just over 500whp on our Mustang AWD dyno.
Weíve been doing a lot of development on our STs and have learned some interesting things that I thought I would share::
Stock R&D Findings
From the factory, our cars are torque monsters. They generate 280lb-ft of torque at the wheels (on our Mustang AWD dyno) from 2,000rpm to 4,000rpm. This gives a LOT of punch off the line and makes them really fun when you jump on the throttle (to the detriment of wheel hop and sad engine mounts). Unfortunately, this power level can be rather inconsistent. We have noticed that engine performance is extremely sensitive to Engine Coolant Temperature (ECT), Charge Air Temperature (CAT), Intake Air Temperature (IAT), and Catalytic Converter Temperature (CCT). When these temperatures increase, the ECU decreases power delivery. There are several factory components that can be improved upon to better handle this engineís peak power output and keep temperatures in check.
Intake R&D Results (Stage1)
Welcome to Speed Density, or, in other words, this is not a MAZDASPEED3! The factory air metering system uses three MAP (Manifold Absolute Pressure) sensors and does not incorporate the MAF (Mass Air Flow) sensors found on many of todayís modern vehicles. What this means for us enthusiasts is that the ECU will be less sensitive to common modifications such as intake upgrades. A MAF sensor meters air mass by detecting voltage changes across a heated wire element in the intake tract. This is a very precise calibration, and altering the air filter or intake system can introduce turbulence or change the airflow pattern across the sensor and affect the sensorís output. This is why vehicles with MAF sensors typically require a retune when the intake is upgraded, which recalibrates the MAF sensor so that it can accurately meter air mass with the new intake. A MAP sensor works purely on air pressure, and does not have the same calibration concerns with respect to changes in airflow or turbulence, which makes making changes to the intake tract less of an issue.
Interestingly, what we have found is that the OEM airbox is well designed and is not a restriction to airflow. We experimented with removing the lid of the airbox, and what we found is that the engine ingests hot air drawn from the engine bay, predictably resulting in higher IAT, translating into a reduction in power. The factory airbox must remain sealed to deliver optimal performance. Aftermarket upgrades that take advantage of the way this well designed factory system draws in cool air from outside the engine bay will produce the most consistent gains in power.
The factory MAP sensor elbow appears to be sized adequately to support power gains up to what the stock turbo is capable of producing. The OEM turbo inlet hose is made of many corrugated pieces, various bends, and pancakes that do a great job of reducing intake tract noise, but do so at the expense of smooth airflow into the turbo. Replacing the OEM turbo inlet hose with a smooth section will optimize airflow into the turbo and allow audible feedback from the turbo and bypass valve.
Power gains with these upgrades will be minimal on their own, but paired with a recalibration of the ECU Ė there are gains to be had here.
Intake + Catback R&D Results (Stage1+)
The OEM catback is a one piece design similar to first generation 2007-2009 MAZDASPEED3. It can be removed by cutting the rear section off and unbolting the remaining front section, or by lowering the rear sub frame for access to remove the entire catback intact. The OEM muffler and resonator are HUGE for a reason; to reduce the enormous sound output of this vehicle.
Our initial catback exhaust designs with minimal components resulted in dB levels comparable to a loud rock concert! After numerous configurations, weíve found the perfect combination for this car.
The catback alone produced minimal gains on the dyno, but does help to decreases exhaust back pressure. This results in more consistent top-end performance by reducing temperatures from run-to-run. The exhaust note is incredible and unique, unlike any hot-hatch Iíve heard before it. Combined with the intake, our cars are almost fully optimized to take advantage of tuning.
Intake+Turbo-Back Exhaust R&D Results (Stage2)
This is the jam. The OEM downpipe inhibits flow, creates back-pressure, and increases temperatures that are ultimately responsible for top-end power inconsistency. There is also an oversized flex-section designed to allow for the astounding amount of engine movement designed into the engine mounts. So much so, that weíve had the engine into the firewall during hard shifts.
Replacing this component will play a crucial role in eventually making big power safely and consistently. Due to the reduction in back-pressure with our downpipe, we did see that temperatures are reduced across the board. This results in more consistent power delivery and a slight bump in top-end power when untuned (~15-20whp). When tuned Ė big.
Conclusions
The ECU in the Ford Focus ST uses torque targets to hit consistent power output in various conditions. This means that the ECU tries to have the engine make the same power in 50 degree weather that it does in 90 degree weather so that the car performs consistently. The ECU does its job so well that despite freeing up restrictions in the intake and exhaust systems, the power gains are not very significant. Adding bolt-on products without tuning will be insignificant. You really need to modify the torque targets to make this one scream.
Finally Ė please donít ask when the AccessPORT is going to be released because Iím definitely not allowed to talk about it.
COBB Tuning is offline
Old 10-19-2012, 09:15 PM   #2
Schroeder02
Moderator
Schroeder02's Avatar
Fan#: 53191
What I Drive: 2013 Red ST & 2009 Focus Race Car
Points 5,488, Level 47
Points: 5,488, Level: 47 Points: 5,488, Level: 47 Points: 5,488, Level: 47
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 62 Schroeder02 Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Thank you for sharing your findings definitely looking forward to what your able to do with the car.
My rides a 2002 SVT track car, & Boosted 2007 ST with the SAP.
The helmet has a special meaning for many drivers. How important is it to you? - It protects my head.
Do you have any special rituals when the helmet is concerned like many have? - I wipe it so that I can see better.
Schroeder02 is offline
Old 10-20-2012, 09:20 AM   #3
rent
rent's Avatar
Fan#: 12823
What I Drive: 03' SVTF
Points 669, Level 13
Points: 669, Level: 13 Points: 669, Level: 13 Points: 669, Level: 13
Level Up 38% Completed
FF Reputation: 2 rent Good Standing Member
Good read. Are there any plans for developing engine mounts that can find the "sweet spot" of movement and driving comfort? I'm sure those that AutoX their rides would be very interested in isolating excess movement.
-James
'03 SVTF *FOR SALE*
'14 FoST Ingot Silver, bone stock...
rent is offline
Old 10-20-2012, 10:46 AM   #4
Black00ZX3
Fan#: 104714
What I Drive: '12 Silver Focus
Points 1,902, Level 26
Points: 1,902, Level: 26 Points: 1,902, Level: 26 Points: 1,902, Level: 26
Level Up 2% Completed
FF Reputation: 3 Black00ZX3 Good Standing Member
Very informative post.
This seems to be the common consensus here on the forum.
Black00ZX3 is offline
Old 10-20-2012, 02:16 PM   #5
eagle_eye735
eagle_eye735's Avatar
Fan#: 90674
What I Drive: 2005 ZX3, 1999 Triumph Sprint ST
Points 989, Level 16
Points: 989, Level: 16 Points: 989, Level: 16 Points: 989, Level: 16
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 4 eagle_eye735 Good Standing Member
Great post, looking forward to seeing more!
Hatch Nation #162
2005 Sonic Blue ZX3 SES
|K&N Typhoon CAI|Magnaflow Catback Exhaust|Megan Racing Springs|Front Strut Brace|SVT 21mm Rear Sway Bar|Prothane Bushings and Endlinks|Steeda STS|
eagle_eye735 is offline
Old 10-20-2012, 04:05 PM   #6
FLYLOW
FLYLOW's Avatar
Fan#: 34077
What I Drive: Gen Coupe Rspec
FF Reputation: 4 FLYLOW Good Standing Member
will this void my warranty?
lol sorry i had to
FLYLOW is offline
Old 10-21-2012, 03:27 PM   #7
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
this should have been stickied by know, such a great post.
also from what i gather from this is that you guys are working on tuning, exhaust and engine mounts. replacement tubing for turbo? then maybe an intake seeing as to how you guys did find that the intake has a realy good design to it?
hn155: Rockford punch pro speakers, t400.4 deh 80prs, full audio build to come. working towards 175hp n/a, simple but fun.
alaskanzx5 is offline
Old 10-21-2012, 09:13 PM   #8
frinesi2
frinesi2's Avatar
Fan#: 95914
What I Drive: 2012 Tuxedo Black SE Sport Hatch
Points 126, Level 2
Points: 126, Level: 2 Points: 126, Level: 2 Points: 126, Level: 2
Level Up 52% Completed
FF Reputation: 1 frinesi2 Good Standing Member
Do you think the 2.0 ecoboost has more total power potential than the 2.0 Duratec Ti-VCT?
2012 Focus SE Hatch 5spd sport package, Tuxedo Black Metallic
Road Magnet springs and fuzzy dice on the mirror
frinesi2 is offline
Old 10-22-2012, 01:33 AM   #9
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
saw a few pages talking about cobb in a modified magazine. read through most of it in while the wife was doing her shopping. great read, cobb is realy doing a lot with the st.
Old 10-22-2012, 06:42 AM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Considering that most factory turbo engines have, or require, forged rods and pistons, then yes, the already boosted engine has more power potential.
What would make you think otherwise?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
