New IMRC Actuator Still Get Code P1518 - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-28-2013, 05:06 PM   #21
LongDucDong
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
Points 9,500, Level 65
Points: 9,500, Level: 65 Points: 9,500, Level: 65 Points: 9,500, Level: 65
Level Up 50% Completed
FF Reputation: 10 LongDucDong Great Standing Member
Did you ever remedy this?
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
Old 05-28-2013, 06:20 PM   #22
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,233, Level 41
Points: 4,233, Level: 41 Points: 4,233, Level: 41 Points: 4,233, Level: 41
Level Up 42% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Originally Posted by bbcobra View Post
ok, nearing time to get an inspection so I may have to deal with this again.
Mine moves the runner flap on start up as it should. then springs back after a few seconds.
That's what mine did when it was bad. I replaced it and no problems. The harness is plugged n all the way, right?
I now drive a Japanese Ford.
macdiesel is offline
Old 05-29-2013, 08:35 AM   #23
bbcobra
bbcobra's Avatar
Fan#: 88400
What I Drive: 2003 SVT Competition Orange EAP ZX3
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 bbcobra Good Standing Member
yes, it's plugged in fine. trying to find some time to work on it now. I was just also trying to find out what models have a box that is a plug & play. The cable should be easy to swap out if they are the same on the box end. I just wanted to verify this with some one before I started looking for a used IMRC from another model car.
03 SVT Focus, Comp Orange, EAP, Eibach sway bars, H&R Race Springs, Koni Sports, steeda shifter, Massive camber arms, toe links, engine mount bushings, sway bar end links.
other car: 2004 SVT Cobra Coupe, Screaming Yellow, 2.76/2lb lower...
bbcobra is offline
Old 05-29-2013, 11:39 PM   #24
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,273, Level 35
Points: 3,273, Level: 35 Points: 3,273, Level: 35 Points: 3,273, Level: 35
Level Up 49% Completed
FF Reputation: 3 paulg127 Good Standing Member
There is an IMRC sensor somewhere. I an not sure the sensor is, but the SVT strategy has a switch for a sensor and it is enabled.
What exactly is the code?
paulg127 is offline
Old 05-30-2013, 07:18 AM   #25
bbcobra
bbcobra's Avatar
Fan#: 88400
Points 430, Level 8
P1518
I believe the whole system is contained within the IMRC. The contactor switch in the IMRC makes contact and breaks contact when the cam moves from one exteme to the other. All this is good, cleaned, repaired. The motor activates as I stated before. The OP had the same symptoms I'm having and a new IMRC did not solve the problem. I don't mind replacing the IMRC if that would solve it but I've seen a few cases now where a new IMRC did not fix it.
bbcobra is offline
Old 05-30-2013, 09:43 PM   #26
boardliquid01
boardliquid01's Avatar
Fan#: 114884
What I Drive: 2003 Silver Ford Focus SVT EAP
Points 573, Level 11
Points: 573, Level: 11 Points: 573, Level: 11 Points: 573, Level: 11
Level Up 46% Completed
FF Reputation: 2 boardliquid01 Good Standing Member
Do you have a wiring schematic of the PCM and IMRC connector? If not I can send you a screen shot. This also may help you as;
The IMRC system is monitored for failure during continuous, key ON engine OFF or key ON engine running self-test. The test fails when the signal on the monitor pin is less than an expected calibrated range at closed throttle.
An IMRCM PID reading approximately near 1 volt at closed throttle may indicate a fault. If you don't have a diagnostic tool, you can manually monitor voltage at the PCM using a DVOM.
-IMRC monitor signal circuit shorted to PWR, GND or SIG RTN
-Loose pin fit at the IMRC actuator (most likely) or PCM (least likely)
-Damaged IMRC actuator (can probably cross this one out)
-Damaged IMRC module
Last edited by boardliquid01; 05-30-2013 at 09:47 PM. Reason: Changed PCM to IMRC module
boardliquid01 is offline
Old 05-30-2013, 11:09 PM   #27
bbcobra
bbcobra's Avatar
Fan#: 88400
Points 430, Level 8
No I don't have one. I'd appreciate that. Thanks for the info.
bbcobra is offline
Old 05-31-2013, 07:06 AM   #28
boardliquid01
Fan#: 114884
Here is the PCM and IMRC wiring diagram
Attachment 18209
IMRC connector
Attachment 18208
Old 05-31-2013, 07:58 AM   #29
bbcobra
bbcobra's Avatar
Fan#: 88400
Points 430, Level 8
thanks
bbcobra is offline
Old 05-31-2013, 12:39 PM   #30
marko2751
Fan#: 115270
What I Drive: 2002 sonic blue svt focus
FF Reputation: 1 marko2751 Good Standing Member
i had the same problem. the cable that's used to open the valve at the intake was seized. wd40 it and work it back and forth and you should be good. your actuator motor box is fine but i can't open/close a cable that is half seized.
marko2751 is offline
