Thermostat Housing Questions? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-20-2012, 01:53 PM   #21
CellshadedSVT
CellshadedSVT's Avatar
Fan#: 51886
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 1 CellshadedSVT Good Standing Member
For sure, I will definitely be calling Steve once I have the money to buy the housing. If you fallow the link to Focaljet that jwill2489 posted, it has all the info about the '98 vs '00 contour housing from Steve himself. I don't know for sure how the '00 stacks up against the '98 as far as stoutness, that would probably be something to ask Steve or just trying each one to see. But like others have said, the '00 has the small temp sensor hole, which, is closer in size to what is on the SVT.
Sniper Focus, I take it those are the part numbers for those items? If so, that is awesome and thank you, always tough to find the right part numbers for things on the SVT.
CellshadedSVT is offline
Old 10-23-2012, 05:47 AM   #22
GBPackFan
GBPackFan's Avatar
Fan#: 84314
What I Drive: 2004 Sonic Blue SVT
Points 1,774, Level 24
Points: 1,774, Level: 24 Points: 1,774, Level: 24 Points: 1,774, Level: 24
Level Up 74% Completed
FF Reputation: 3 GBPackFan Good Standing Member
Buy-Sell-Trade Rating: (8)
Steve owns a SVTF, tell him you have one and need a t-stat housing. He WILL know exactly what to send you. Trust me, he will not sell you a SVTF t-stat housing unless you specifically ask for that. Even then he might ask you why you would want that one specifically..
Current love affair: 2004 SVTF #953 (Josephina - pronounced hoe-se-fin-a)
RIP: 2002 SVTF #2358, Sent to graveyard on June 11, 2013. I will always remember the good times we had!!
This car made my hair go gray, and did not care.
GBPackFan is offline
Old 10-23-2012, 11:12 PM   #23
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
FYI, I used to take back lots of warranty Dorman water necks for failure, the plastic absolutely sucks, they crack very easy as compared to OEM.
amc49 is offline
Old 07-23-2013, 03:27 PM   #24
samus
Fan#: 53177
What I Drive: 2002 Pitch Black SVT
Points 126, Level 2
Points: 126, Level: 2 Points: 126, Level: 2 Points: 126, Level: 2
Level Up 52% Completed
FF Reputation: 2 samus Good Standing Member
I hate to revive a 1yr old thread, but I wanted to comment on the coolant housing and a very inexpensive fix.
My housing has cracked TWICE on my current SVT and once on my previous 02 SVT.
However, the second time it cracked, I decided not to replace it, or upgrade to the $150+ Contour option that requires me to replace functional sensors with Contour-compatible ones.
The fracture point is the same every single time. Below where the thermostat retainer meets the housing, along an injection point. I wish I took pictures, but basically its a horizontal crack along the bottom freeze-plug fitting against the block.
Running some water through the housing in my sink I was able to clearly see this is where, and only where, the leak occurs. Very unwilling to give Ford more money at this stage for what is effectively a chronic design flaw spreading a decade of Focii (from the 98 1.8L-2.0L in UK to the 00-07 Zetec in the USA) I decided to repair it with JB Weld.
I lightly filed down and cleaned with alcohol any burrs or jags in the crack, then intentionally put some jags every few millimeters along the crack to aid weld rigitity, and lastly injected two-part JB Weld Plastic epoxy into the crack until I saw it seep into the housing near the freeze-plug hole. I cleaned up quickly with toothpicks and let it dry.
It's held for over a month in a very hot Chicago summer with constant 90's and AC use. No leaks. Cost: $6.00
samus is offline
Old 07-23-2013, 03:35 PM   #25
samus
Fan#: 53177
Points 126, Level 2
This is a modification showing where the housing leaks (at least where all mine have leaked) thanks OP (CellshadedSVT)
Uploaded with ImageShack.com
samus is offline
Old 07-26-2013, 06:54 PM   #26
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
That's not the normal location of the common break!
Usually the housing breaks around the large o-ring, that contacts the engine block.
This usually happens when oil runs down from the head (valve cover, VCT solinoid, etc.) and contacts the rubber o-ring causing the o-ring to swell and the plastic to break. I am well into 250,000km's with no housing issues, as I make sure that I have no oil leaks and I have also replaced the standard Butyl o-rings with Viton and also do not suffer any of the common o-ring leaks as well. The Viton o-rings cost me less than $5.00 for a package of each size and the time to replace. The Butyl o-rings would only last 2 years, like clockwork!
Steve is very knowledgable and his pricing is second to none, but the Contour housing upgrade is an over reaction in my book and the CF aluminum upgrade is a complete waste of money!
I don't know why you are suffering this break, but I would bet that something unique is causing it?
It's just my opinion, so take it as such...
Good luck...
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
Old 07-26-2013, 07:25 PM   #27
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,073, Level 27
Points: 2,073, Level: 27 Points: 2,073, Level: 27 Points: 2,073, Level: 27
Level Up 49% Completed
Forum Activity 9%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I upgraded for preventative maintenance, but when I took it off it was on its way to failure. This is the usual failure point...
The contour housing has been on my car for 3yrs and its been trouble free. I haven't priced them since, but it wasn't anywhere near $150.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is offline
Old 07-26-2013, 07:45 PM   #28
lmcd314
lmcd314's Avatar
Fan#: 90550
What I Drive: 00 spi-sold, 2003 cd-silver SVT zx5
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
FF Reputation: 1 lmcd314 Good Standing Member
i used the Central Florida Motorsports svt housing, had it a few months, no leaks, no complaints.
lmcd314 is offline
Old 08-05-2013, 02:12 PM   #29
golfitup
golfitup's Avatar
Fan#: 81087
What I Drive: #93 H-Street 2002 Focus SVT
Points 809, Level 15
Points: 809, Level: 15 Points: 809, Level: 15 Points: 809, Level: 15
Level Up 9% Completed
Forum Activity 12%
FF Reputation: 1 golfitup Good Standing Member
Anyone else have experience with the CFM unit? Looking for a new one now . . .
golfitup is offline
Old 08-05-2013, 03:44 PM   #30
Sniper Focus
Fan#: 84221
Forum Activity 9%
Yeah almost 3 yrs running strong, the CFM "kit" is just the Contour housing from 99-00. You can probably get it cheaper through Village Ford or Autonation Ford.
Steve at Autonation (Tousley) said that he never really sold a Contour housing for an actual Contour, only for an upgrade for the Focus.
