Swapping Audiophile System - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-17-2012, 02:42 PM   #1
Sully313
Sully313's Avatar
Fan#: 104895
What I Drive: 03 SVT ZX5 Red, 06 ZX3 SES Black
Points 1,242, Level 19
Points: 1,242, Level: 19 Points: 1,242, Level: 19 Points: 1,242, Level: 19
Level Up 43% Completed
FF Reputation: 1 Sully313 Good Standing Member
Is it possible to swap an Audophile system into SVT 5dr not originally equipped with it?
I don't want an aftermarket system.
Currently the volume button in the car is acting funky so I'm looking for a stock replacement and I would like to upgrade to the audiophile system w/the sub. I was kind of bummed when I found out the car wasn't equipped with it when I looked at it but I bought it anyway. I would also like to keep the steering column controls.
Is it possible? What parts would I need besides the obvious radio and sub?
Sully313 is offline
Old 10-17-2012, 05:47 PM   #2
FocusHero
Fan#: 100491
What I Drive: 2003 Black Svt
Points 1,137, Level 18
Points: 1,137, Level: 18 Points: 1,137, Level: 18 Points: 1,137, Level: 18
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 FocusHero Good Standing Member
I believe the stock radio and audio pile have the same wire harness so all you need is the sub harness and you just have to run wires for the sub which is very easy if you have any audio sense at all just find a diagram floating around on here for the amp
svt dohc: eibach spring, k&n intake, magna flow 2.5, light weight flywheel and 69mm throttle body
SVT or die!!!!!
FocusHero is offline
Old 10-17-2012, 10:35 PM   #3
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,865, Level 25
Points: 1,865, Level: 25 Points: 1,865, Level: 25 Points: 1,865, Level: 25
Level Up 65% Completed
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
I believe all SVTs came with the sub harness installed whether it had the sub or not. It should be as simple as buying and installing the HU and the sub/amp. I happen to have a sub/amp with carpet. If you are interested, PM me. Good luck.
mainest is offline
Old 10-21-2012, 01:02 PM   #4
Sully313
Sully313's Avatar
Fan#: 104895
So, If I was sub harness, where would I be? Where should I look for it? I tried a search for the sub connections but was unable to find anything that helped.
Sully313 is offline
Old 10-21-2012, 07:46 PM   #5
Sully313
Sully313's Avatar
Fan#: 104895
Found it! Once I got the carpet trim off, it was fairly obvious.
Sully313 is offline
Old 10-21-2012, 11:15 PM   #6
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,622, Level 43
Points: 4,622, Level: 43 Points: 4,622, Level: 43 Points: 4,622, Level: 43
Level Up 36% Completed
Forum Activity 3%
FF Reputation: 28 ah1f39 Great Standing Member
If the only problem is the volume knob, you can get the steering wheel audio control. They work great.
ah1f39 is offline
Old 10-21-2012, 11:42 PM   #7
Sully313
Sully313's Avatar
Fan#: 104895
Mine has the volume control on the column.
With this radio. I'm assuming that this radio lacks the sub harness provisions.
Sully313 is offline
Old 10-21-2012, 11:50 PM   #8
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
Forum Activity 3%
No sub on that. You can use an LOC to hook up a subwoofer. There many how to's.
You will get more bass than the Audiophile by using an LOC from both rear channels.
ah1f39 is offline
Old 10-22-2012, 08:05 AM   #9
Sully313
Sully313's Avatar
Fan#: 104895
I don't want to go that far. I was just trying to take the easy way out and plun-n-play.
Sully313 is offline
Old 10-23-2012, 06:22 PM   #10
Sully313
Sully313's Avatar
Fan#: 104895
I acquired a sub, amp and carpet but the sub has a 09 part number and the carpet has a 08 number. I'm assuming it won't work. I tried a test fit and I think there are subtle differences. The carpet looks like it wraps around the back side of the box too. Also the location of the plug for the amp is towards the back. but the amp could be mounted with the amp input towards the font..
Anyone have info/input on this?
Sully313 is offline
