Driving in sport mode shifting from 2-3 problem? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 10-17-2012, 01:19 PM   #1
k1ngkev1n1
Fan#: 103124
What I Drive: 2012 ford focus SEL
FF Reputation: 1 k1ngkev1n1 Good Standing Member
i noticed when i shift from 2nd - 3rd using select shift in sport mode it takes a second. It revs the engine and then shifts but shifting from 1-2 and 3-4-5-6 shifts fine its just 2-3 any reason for this? is it normal? am i shifting too early or too late? just curious what you guys thought.
k1ngkev1n1 is offline
Old 10-17-2012, 01:34 PM   #2
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
FF Reputation: 2 cbdallas Good Standing Member
You might want to take a technician for a ride so he can see what it's doing. It sounds like something is causing a delay with whichever clutch powers 3rd gear, although it's strange that it doesn't affect the 4-5 shift as well. Reving between shifts can cause accelerated clutch wear. Any other wierd behavior? Shuddering from a stop?
cbdallas is offline
Old 10-17-2012, 01:38 PM   #3
k1ngkev1n1
Fan#: 103124
when in sport mode it doesnt studder from start, when in drive mode it will mainly in the early morning, some rattling mainly when driving slowly atleast thats when i can tell mostly.
Old 10-17-2012, 01:46 PM   #4
cbdallas
cbdallas's Avatar
Fan#: 100296
Judging from what I'm seeing on this forum, a lot of people's clutch problems stem from a leaky transmission input shaft seal, which basically allows oil to get onto the clutches. This can cause them to be grabby, or slip depending on the quantity of oil. Take it in, and see if you can get a service advisor or tech to take a ride with you.
cbdallas is offline
Old 10-17-2012, 01:49 PM   #5
k1ngkev1n1
Fan#: 103124
ok should i wait till after my first oil change or just take it in? i have 2000 miles on it. 2012 focus SEL sedan built july 2012
Old 10-17-2012, 01:54 PM   #6
cbdallas
cbdallas's Avatar
Fan#: 100296
Whatever is convenient for you. They're not going to care if you've had your oil changed or not.
cbdallas is offline
Old 10-17-2012, 02:00 PM   #7
k1ngkev1n1
Fan#: 103124
Just placed a service appointment for saturday morning... wonder how long it will take for them to check it out ....
Old 10-17-2012, 03:06 PM   #8
Kabigon
Fan#: 88299
FF Reputation: 8 Kabigon Good Standing Member
Try shifting from 2 > 3 at a higher speed and see if it doesn't shift faster.
Kabigon is offline
Old 10-17-2012, 03:17 PM   #9
k1ngkev1n1
Fan#: 103124
yea ive tried that but seems the rpms go way up and still does the same. Im taking it to ford torrance saturday hopefully they can fix it. maybe i need an update or something..
Old 10-18-2012, 01:29 PM   #10
sogosu
Fan#: 104452
What I Drive: 2012 white platinum titanium hatch
FF Reputation: 1 sogosu Good Standing Member
How high do your revs climb when shifting from 2nd to 3rd?
I picked up my 2012 Focus Ti hatchback (7/12 build) yesterday and started noticing the same thing.
When I drive in S mode and shift at around 2000 rpms from 2nd gear it continues to rev for about a second to 2700rpms before 3rd is engaged even though the display shows I'm in 3rd. If I shift from 2nd at 3000rpms it revs for about a second to 3800rpms before engaging 3rd gear. Other 1-2, 3-4, 4-5, 5-6 are all smooth and instant.
I'm lucky I don't have the shuddering or other accelerating issues some people on here have (knock on wood) but this is still pretty significant.
Please let us know what the dealer says.
I'm booking a service appointment next week.
sogosu is offline
