Trouble filling up gas tank. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-15-2012, 10:14 AM   #1
2•ohh
Fan#: 97690
What I Drive: Ford Expedition And Lightning
FF Reputation: 1 2•ohh Good Standing Member
The other day as I was filing up the pump kept on shuting down every 1/4 gallon or so. Very annoying, and since I was running late for work I only put 2 gallons in. On the way home I figured I'd fill up the rest of the way at a different gas station, Well, Same thing happened. Pump was shutting off at 1/4 gallon increment or so. Is it a freak thing or has other people had this problem? Ill see if it does it on next fill up.
2•ohh is offline
Old 10-15-2012, 10:34 AM   #2
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,358, Level 42
Points: 4,358, Level: 42 Points: 4,358, Level: 42 Points: 4,358, Level: 42
Level Up 4% Completed
Forum Activity 5%
FF Reputation: 9 darkangelism Good Standing Member
The pump is told to shutoff based on backpressure, so if it keeps doing it there could be something wrong.
darkangelism is offline
Old 10-15-2012, 10:42 AM   #3
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 4,355, Level 42
Points: 4,355, Level: 42 Points: 4,355, Level: 42 Points: 4,355, Level: 42
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 2%
FF Reputation: 1 raptor1956 Good Standing Member
I've run into bad pumps/nozzles in the past that would only squeeze out a shot at a time unless you squeezed the handle a lot less and slowed the flow. Some of the nozzles are AFU -- it's unlikely you have a problem with you has tank.
However, if you continue to have this problem and at other gas stations then bring it to the dealer...
Brian
2012 FF Ti HB Sonic Blue, Built 5/7/12, 401A + Parking Technology Package and MFT w/NAV 3.0.2 -> 3.2.2 -> 3.5.1 -> 3.6.2
raptor1956 is offline
Old 10-15-2012, 11:58 AM   #4
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,720, Level 78
Points: 14,720, Level: 78 Points: 14,720, Level: 78 Points: 14,720, Level: 78
Level Up 68% Completed
Forum Activity 11%
FF Reputation: 16 Elizabeth Great Standing Member
That particular pump is set to deliver fuel faster than it can go down your tank pipe.
Use a different pump.
Where I usually buy gas, the pumps can flow far more gas than my tank can accept.
I just squeeze the handle less. Then less fuel is pumped per second, and the device does not shut off the pump.
The flaw is the person setting the fuel flow, and such at the station.
Elizabeth is offline
Old 10-15-2012, 12:14 PM   #5
2•ohh
Fan#: 97690
This did happen at 2 different pumps and even when I tried to slow the gas flow down it still would cut out. Im curious to see if it does this on next fill up. If it does I'm going to make an appointment at the dealer.
2•ohh is offline
Old 10-15-2012, 01:14 PM   #6
leh0825
[:)][:)][:)][:)] I got this!!!!
leh0825's Avatar
Fan#: 63206
What I Drive: 04 F250 FX4 6.0L
FF Reputation: 8 leh0825 Good Standing Member
had this happen on two work trucks. there should be a little flange near the tank that if it gets moved or damaged (in the case some one is trying to siphine gas). or your breather tube is.damaged. doesn't allow the air to come.back up.
Team Duratec #220/Sedan Revolution #179/NW Posse#5
Originally Posted by jmiller_1974 View Post
Geesh. I mean I know it's just a Focus to the repair shop, but they couldn't give You something other than a rolling vagina to drive?
leh0825 is offline
Old 10-21-2012, 07:54 PM   #7
2•ohh
Fan#: 97690
Just filled up Friday. This time yet another gas station and same thing seems to be happening. Time for a call to the dealer.
Posted via FF Mobile
2•ohh is offline
Old 10-21-2012, 10:12 PM   #8
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
Points 3,162, Level 34
Points: 3,162, Level: 34 Points: 3,162, Level: 34 Points: 3,162, Level: 34
Level Up 75% Completed
FF Reputation: 6 craigsfocus Good Standing Member
This happens to my wife's G35x. For the Infiniti, its the gas backing up into breather tube which shuts off the pump. We have to set it at a slow fill speed. Yours is probably doing the same thing. So the dealership should replace the filler tube. This is the first time I have heard of this problem in our Foci. Never happened to me and I have 61 fill ups as of today.
Hopefully your dealership will fix the issue with no hassle.
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 10-21-2012, 10:29 PM   #9
Dark 007
Dark 007's Avatar
Fan#: 80502
What I Drive: 2001 marshall red LX
FF Reputation: 1 Dark 007 Good Standing Member
I'm currently having a similar issue. Check it out, hopefully it'll help.
http://www.focusfanatics.com/forum/showthread.php?p=4395928
Posted via iPhone using FF Mobile
Dark 007 is offline
Old 11-29-2012, 08:50 PM   #10
2•ohh
Fan#: 97690
Ironically I only filled up the car twice since this problem and once it was bad and once it worked fine. My dealership is over an hour away so on its next oil change I'll let them know. Should be in about 2 weeks time.
2•ohh is offline
