2000 Ford Focus ZX3 Zetec DOHC Engine Oil Leak - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-16-2012, 01:45 AM   #11
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
If the gasket is metal then keep using it unless cracked or deformed, it will outlast the car. Nylon or plastic ones will spread or crack, change them from time to time. Not rocket science, just look at it............
amc49 is online now
Old 06-29-2014, 11:51 PM   #12
david5300
Fan#: 113204
What I Drive: 2000 blue chevy astro ls
FF Reputation: 1 david5300 Good Standing Member
I can not even find the oil pressure sensor. The car leaks from the passenger side of the engine. I replaced a brand new oil filter and the mechanic tell me they may have to remove the timing belt I just installed.
Ford Focus is a nice little car as long as you don't have to work on it.
david5300 is offline
Old 06-30-2014, 01:51 AM   #13
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,780, Level 54
Points: 6,780, Level: 54 Points: 6,780, Level: 54 Points: 6,780, Level: 54
Level Up 15% Completed
Forum Activity 47%
Activity: 47% Activity: 47% Activity: 47%
Buy-Sell-Trade Rating: (23)
You replaced the timing belt? Or a shop replaced it?
Sounds like you need to find a better shop to me.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 06-30-2014, 02:24 AM   #14
amc49
Fan#: 96610
Forum Activity 49%
Just gearing the guy up for bigger charges, the timing belt has nothing to do with oil leaks unless someone damaged the crank seal doing the job.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is online now
Old 06-30-2014, 04:02 AM   #15
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 47%
We refer to that as "flat rating" a person.
Scumbag shops outnumber the good shops IMO.
Hatch Nation #140
freemind is offline
Old 06-30-2014, 06:50 PM   #16
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
david5300, do you have the same engine as the OP?
If so, the oil pressure sensor is an inch or two from the oil filter, closer to the passenger side. $20 part and not that bad a repair. Disconnect the wiring plug, get a deep 24mm socket, remove leaky sensor, install good sensor, reconnect plug.
I left out the contortions required to wrap your arms around the axle while you're doing it...and I recommend removing the oil filter for better access, but your call on that. If you're lucky, the original installer left the plug facing away from the filter so you actually have room to press the little tang in to remove the plug easily.
There are many much worse cars to work on...early Renault 5s, for example, where you had to remove the alternator to change the oil filter.
Leora83 is offline
Old 06-30-2014, 10:56 PM   #17
amc49
Fan#: 96610
Forum Activity 49%
Wha..........?? That would surely suck..............
amc49 is online now
Old 07-01-2014, 12:25 AM   #18
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,389, Level 75
Points: 13,389, Level: 75 Points: 13,389, Level: 75 Points: 13,389, Level: 75
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 99%
A Wonder of Engineering in some regards, more often you wondered WHY they ever engineered them as they did. French cars can make Italian cars look German.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 07-01-2014, 07:51 PM   #19
amc49
Fan#: 96610
Forum Activity 49%
Wee wee m'seiur, spaghetti, ravioli, und sauerkrauten, wunderbar!
amc49 is online now
Old 07-02-2014, 04:40 PM   #20
Leora83
Fan#: 69136
Forum Activity 10%
Now that is classic!
Leora83 is offline
